Scotty wrote:Your talking about millions like they matter to toyota![]()
While it's true the double conversion to run the pump is less efficient.sergei wrote:BTW why do you think "Theoretically electric water pumps are far superior to mechanical pumps. "? The alternator runs of the belt as normal mechanical waterpump does. Plus you get electrical losses (3 phase AC->12DC, cable loss - due to substantial current at 12V, electric motor loss, 12V is not the most efficient voltage to run electric motors at.)
Oranges with oranges please. The piston engine has had probably had about 10 times the time and money spent on developing it. The only people who have developed the rotary is Mazda. And yet EVERY car complany builds, and develops the reciprocating piston engine. Forumla one teams alone have spent millions developing their engines. And I would hazard to say that a fair proportion of that development technology engines up in production engines.sergei wrote:Rotors will never be more efficient than same era/technology piston engines, as internally rotors have high surface area, which is really important for fuel efficiency as the fuel left on the walls is the wasted fuel.
Fair enough for the hybrids. But look at all the other cars out there. How many are even close to a cd of .25? Car's touted as family touring sedans have cds in the range of .33-.38 and they are meant to be taken down country for the holidays. While it's true they're not pushing 200kph, but at 100kph aerodynamics start to play a part.sergei wrote:Your argument against the drag efficiency of honda and other hybrid cars, they were designed for city traffic stop-go, and at 30kph it does not matter if it has cd of 0.25 or 0.33...
I agree. Although I still say, like the rotary, the turbo engine is only now getting serious money spent on R&D. If half of the money spent on engine development over the past 15 years was spent on soley on small turbo engines the small turbo engine would probably be quite reliable now.sergei wrote:While you are right about small capacity turbo engines, they are some what inherently unreliable. And the big engines you are talking about are usually of American origin - on which I don't really have high opinion (in other words all those pushrod V8s are crap, I don't care if they have 600Hp or whatever out of that capacity it is not really achivment).
Got any references?Mr Revhead wrote:basic fact, a rotory engine is not as efficiant as a piston engine. been proven many times by ppl such as gordan murray, mercedes, gm etc etc
Better be careful what you say. The newest generation of LEDs have lumen outputs that equal or better any traditional per watt... Of course the low total wattage is a bit of an issue...sergei wrote:LED is not the most efficient or robust technology. HID is the right direction. LED is good for matrix single colour lights (stop, turn, traffic lights etc -> generally displays not lighting). White LED is not really white. The problem with LED that it very temperature dependant. Back of it should be cooled while front of it should be warmed. The brightness/efficience is highly temperature dependant.
Once again, I wonder what could be done if the same amount of R&D had been spent on gas turbine generators/compact electric drive systems as has been on the internal combustion engine.sergei wrote:The problem with gas turbine powered cars is that the turbine itself is highly dependant on maintanance, mistreatment leads to catastrophic results. .... Turbine (or secondary turbine) shaft rotating generator which through voltage convertor/regulator powers electric motors in the wheels.
sergei wrote:The most efficient internal combustion engine is a gas turbine. The only problem it is only efficient in big sizes (as the rotor speed go down as well as relative tolerances are better). Imagine having turbine powered car with hybrid system (as it is the most efficent way to transfer power from something that rotates at >50000rpm). You can run it on diesel with efficiences up to 50% (compare ~25% on piston engines)...
