BZ BLACKTOP TURBO CONVERSION
Postby BLACKTOP_WAGON » Fri Dec 08, 2006 2:19 pm
HI I HAVE SEEN THE SILVER TOP CONVERSION DONE I WAS WONDERING WHAT I COULD USE FROM MY BLACK TOP I CAN PRETTY MUCH EVERYTHING MYSELF EXCEPT TUNING CAN I USE THE BLOCK,CRANK,RODS I WANT TO USE MY HEAD IS IT POSSIBLE TO JUST REPLACE THE PISTONS AND HEAD GASKET AND STILL BOOST LIKE 15PSI
INTERCOOLER IS RACEPRO BRANDNEW AND I GOT A T3 TURBO
PLEASE HELP
BLACKTOP_WAGON
Postby Mr Revhead » Fri Dec 08, 2006 2:25 pm
my first piece of advice is turn off ya caps.
2nd:
you can only use your block, head and crank
you need new rods and pistons
Postby BLACKTOP_WAGON » Fri Dec 08, 2006 2:47 pm
so i just need new pistons and rods do i need a new ecu. i have a 6 speed lsd will that do or do you think it will blow up
BLACKTOP_WAGON
Postby BLACKTOP_WAGON » Fri Dec 08, 2006 3:17 pm
if i get new pistons i guess they with fit my block and head and crank etc
BLACKTOP_WAGON
Postby Silent Knight » Fri Dec 08, 2006 3:26 pm
If you have to ask...
Place bets now? :roll:
Silent Knight
Postby no_8wire » Fri Dec 08, 2006 3:41 pm
buy my 4agze block it has all you need to turbo...execpt the rods...
brand new low comp pistons and rings, pm me...
8)
no_8wire
Postby Santa'sBoostinSleigh » Fri Dec 08, 2006 3:42 pm
mate, not sure if you realise how much its ging to cost to turbo your car, its not as simple as whacking a turbo on
it costs literally thousands... (ie ~$5000+)
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby BLACKTOP_WAGON » Fri Dec 08, 2006 4:57 pm
cant be that much considering i all ready have a manifold and turbo and intercooler and i am a mechanic but just need to know about toyotas in my spare time i have been making up the piping so i just need to know what i have over looked
BLACKTOP_WAGON
Postby Santa'sBoostinSleigh » Fri Dec 08, 2006 5:03 pm
depends how long you want it to last
ECU
rods
pistons
cert
wiring
intake manifold (stock is no good)
injectors
bov
fueling - pumps lines etc
wastegate
and as you said
turbo
exhaust manifold
intercooler
i/c piping
most people use GZE block/crank/pistons/rods etc, smallport non-tvis manifolds,
Santa's Mega Sale
Postby mr pad » Fri Dec 08, 2006 5:33 pm
Give the guy a break. It sounds like he knows what hes doing and asked the right questions..
mr pad
Postby Bazda » Fri Dec 08, 2006 8:51 pm
use the blacktop head
you will need all the stuff santa has said +
stronger valve springs for the BT head
a plenum to suit the thorttle bodies with an adapter plate
A ecu that can handle the quads . ie autronic ($2k+)
