What springs are fxgt club car owners using??? AE82 fxgt
Postby GOLDAE86 » Thu Nov 30, 2006 9:38 pm
If you r going to use the car for street events and hill climbs etc the best set up that i have driven on is
*lowered king srings (not super lows)
*KYB twin gas shocks
*Thicker rear roll bar
*1 to 1.5 degrees of camber front and rear
*Between 5 and 8 degrees of caster
*about 1mil of toe out in the front end and zero in the rear end
Am in the process of building the suspension for an ae82 for track racing so am wanting to use king springs and bilsteins ( or twin adjustable konis) platform adjustable struts front and rear big front roll bar even bigger bar in the rear more caster adjustment in the front end more camber adjustment front and rear.As for spring weights have not worked that out yet.
Hope this helps
To finish first, first you must finish
GOLDAE86
Real Life Mechanic
Postby Mr Revhead » Thu Nov 30, 2006 9:47 pm
note: the above mentioned king springs are king prosport coil over springs
a world of difference form king lowering springs :wink:
Postby crispy'86 » Fri Dec 01, 2006 12:19 pm
Yes it's at ruapuna doing different courses, full grand prix course, club circuit with and without dipper. At high and low speeds it sits fine on the track, the extra rear swaybar clamped onto the original one, making it 2 factory swaybars has reduced understeer i previously had, there's a rair bit of body roll on cornering and reason the spring rate in the front needs to be stiffer is to reduce the bodyroll. And the back end becomes quite light under braking and in the wet is all more fun when all the weight distribution is on the front of the vehicle. Had someone with me that's pedalled a few cars round in previous years and it feels quite soft under braking, i am using cobra springs after all so their designed purely for road use and my intention is to get custom springs. The findings are it is quite soft in the front and car almost nosedives under braking. Spring rate i have couple of friends helping me to work out what i have. Also worked out set of lovells springs i have for rate too. Main thing is getting the back of the car low and i'll be tackling/ experimenting tonight with different spring pairings
crispy'86
Postby trdfxgt » Sun Dec 03, 2006 11:15 am
i have trd strut inserts in mine ithe fitted strait in no mods i have fitted threads to my struts and are running adjustables i have king 350lb front springs and 250lb dobi rear race springs at the old taupo track this set up gave me 3 seconds on that track thats a huge change this cost me just under 600 dollars to so its not a dear way to go (also how did you fit two sway bars ? does it work ?)
trdfxgt
Postby Bling » Sun Dec 03, 2006 11:21 am
he uses quite a few hose clamps (the metal ones tighened with screwdriver or socket) to hold the 2nd bar to the one bolted to the car, , seems to work sweet
Postby trdfxgt » Sun Dec 03, 2006 11:25 am
does anyone no if a rear strut bace will have a similar effect ?
trdfxgt
Postby Dell'Orto » Sun Dec 03, 2006 12:50 pm
No it wont.
Postby trdfxgt » Sun Dec 03, 2006 1:01 pm
i thought so was more asking out of curiousity
trdfxgt
Postby Dell'Orto » Sun Dec 03, 2006 1:02 pm
Gotta ask to find out ;)
Postby crispy'86 » Mon Dec 04, 2006 5:51 pm
BZG|Bling wrote:he uses quite a few hose clamps (the metal ones tighened with screwdriver or socket) to hold the 2nd bar to the one bolted to the car, , seems to work sweet
Huge improvement in handling stakes, reduced all the understeer troubles i had,
crispy'86
Postby trdfxgt » Tue Dec 05, 2006 10:53 am
post some pics of your car crispy ! ae 82 race cars
trdfxgt
Postby crispy'86 » Wed Dec 06, 2006 12:32 pm
when i get the digi camera and lead i'll try and upload some pics
crispy'86
Postby crispy'86 » Tue Dec 12, 2006 10:54 pm
warwick: E-mailed ya, not sure if you got it. Just need prices and availability of some options
crispy'86
Postby crispy'86 » Wed Dec 13, 2006 10:31 pm
trdfxgt wrote:i have trd strut inserts in mine ithe fitted strait in no mods
Is yours an ae82?? And was it the rears that you could put the adjustable inserts into? straight fitment?? Reason i ask is suppliers only have listings for the standard complete shopck as a unit, i'm more than willing to prove them wrong.
As for the pricing i'm going to get the full details to you soon warwick
crispy'86
Postby shazeal » Wed Dec 13, 2006 10:51 pm
Place like chamberlains will convert struts to fit inserts, have to do that if you go with bilstein afaik.
Current - 83 Levin AE85 Notch.
Ex - 89 Sprinter - Red Top, 88 Levin - 4agze.
shazeal
Postby trdfxgt » Thu Dec 14, 2006 4:12 pm
both front and rear i think both where insert type struts (not all are from what i understand) and yes ae 82 hatch take them out and have a look at them see if there is a nut on the top of each strutt ?
when i think of something witty ill put it here
trdfxgt
Postby ChaosAD » Thu Dec 14, 2006 6:07 pm
Got Koni adjusties in my ae82 fx.
For the fronts you undo the nut on the top of the struts, pull the guts out, replace with an insert and do the nut up.
The rears are sealed, so you cut the top off, pull the guts out, and drill a hole in the bottem to bolt the insert in.
Should say on the trd website if they inserts or not, there is also a page where you can cross referance the part numbers and get the dimentions of the inserts
ChaosAD
Postby crispy'86 » Thu Dec 14, 2006 6:13 pm
ChaosAD wrote:The rears are sealed, so you cut the top off, pull the guts out, and drill a hole in the bottem to bolt the insert in.
Yip i'm aware of the fronts being able to be replaced with inserts as i've done this already but rears i wasn't so sure about. Been quoted $120 to get my gabriel shocks machined down / shortened to suit the spring but if it costs that much then i may aswell price up TRD inserts
crispy'86
Postby crispy'86 » Tue Jan 30, 2007 7:05 am
Okay i've done some measuring up, watch the faq section carefully in next few weeks :wink:
crispy'86
