Boost Gauge...How high above desired level?
Postby no_8wire » Thu Dec 14, 2006 2:33 pm
As above ...I bought the gauge when i was going to be running 15psi...however now I am going to be running 18psi as a daily and 20psi fo the track...
But the gauge only goes up to 20psi...
My question: is this ok? Or do I need to get a gauge that goes higher? And if so how high?
no_8wire
Postby Adydas » Thu Dec 14, 2006 2:39 pm
Hrm intresting, all they change is the background image, other than that there identical
Adydas
Postby Dell'Orto » Thu Dec 14, 2006 2:39 pm
As long as its accurate and your boost control is sweet, then why bother?
Postby IH8TEC » Thu Dec 14, 2006 2:41 pm
why you need higher if your going to be running 20psi? i have a 20psi guage because i run up to 20psi, with the external and my boost controller i'm not worried about spiking over that at all. if your wastegate control is crap and spikes, it might be worth while
the only reason i'm changing mine to a 30psi one is because i'm plannng to run 25psi 8)
Postby no_8wire » Thu Dec 14, 2006 2:45 pm
I dont know what my wastegate is like...as I have never had it running!
:lol:
Running a TD05h off a Evo4...with internal, and boost control via a link solenoid....
Guess I will just have to wait and see!
no_8wire
Postby Santa'sBoostinSleigh » Thu Dec 14, 2006 2:55 pm
Adydas wrote:Image
as you would expect, ones in bar and ones in PSI is it not?
and no8, personally i would get one that went ~5PSI higher than what you intend to run - gives you some leeway
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby mr pad » Thu Dec 14, 2006 3:49 pm
It will look awesome wrapping the whole way round the gauge 8) :lol:
mr pad
Postby Mr Revhead » Thu Dec 14, 2006 3:56 pm
you wont know if its over boosting if it stops where you run it.
Postby Adydas » Thu Dec 14, 2006 4:33 pm
Just get and use a AVCR, Does control as well as a nice digi display.
Adydas
Postby 4000GT » Thu Dec 14, 2006 4:51 pm
Adydas wrote:Just get and use a AVCR, Does control as well as a nice digi display.
Ummm why spend hundreds on an Apexi boost control when he has a Link solenoid doing all that already? Which may be a denso unit depending which he has. He only needs a gauge that meets his needs, which is one which reads over 20psi. A mechancial VDO units can be had for under $100, hundreds less than buying a complete new boost control system.
Supra MKIV Aerotop (UZA80FTE conversion) STATUS: 3 months to go!
Nitrous is like a hot chick with a STD..... you know you wanna hit it, but you are afraid of the consequences.....
Free online business and reporting tools visit www.e-solver.com
4000GT
Postby Adydas » Thu Dec 14, 2006 5:17 pm
its just another option, it seems like thats what hes after its not like i expect him to buy the defi guage i posted up either.
Adydas
Postby 4000GT » Thu Dec 14, 2006 5:23 pm
Adydas wrote:its just another option, it seems like thats what hes after its not like i expect him to buy the defi guage i posted up either.
Ah ok, well you did tell him to get the AVCR thats all... I dont see why he seems to be after a new boost control system when he has one bt just runs out of range on the gauge he has...
Anyways, here is a source I have often for gauges. Boost gauge linked.
http://www.egauges.com/eg_typeI.asp?Typ ... l&Manf=All
4000GT
Postby Adydas » Thu Dec 14, 2006 5:33 pm
The ultimate in cool is those blue ones, evryone wants those.
Adydas
Postby Akane » Thu Dec 14, 2006 5:56 pm
real gauges count is kPa's :oops:
Postby no_8wire » Thu Dec 14, 2006 11:32 pm
cheers...what I thought
no_8wire
Postby QikStarlie » Thu Dec 14, 2006 11:36 pm
why not just use the current one, and set the boost cut on the link to 22-23 psi
QikStarlie
Postby no_8wire » Thu Dec 14, 2006 11:43 pm
How am I to know when it is at 22psi if the gauge finishes at 20?
no_8wire
Postby GorGasm » Fri Dec 15, 2006 12:01 am
because itll hit boost cut? lol
Seriously, 5 psi higher than your level will be fine
GorGasm
Postby matt dunn » Fri Dec 15, 2006 12:48 am
dont be a tight arse.
Go buy a new gauge.
Otherwise, when it spikes and shaggs something you'll regret it.
Postby EVLGTZ » Fri Dec 15, 2006 1:47 am
no_8wire wrote:Running a TD05h off a Evo4...with internal, and boost control via a link solenoid....
I reckon that'll spike a fair bit. The internal wastegates on those arent great.
Get a gauge that reads to say 2 bar for peace of mind and as kris said, set the boost limiter in ya link for safety
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
