Boost Gauge...How high above desired level?
As above ...I bought the gauge when i was going to be running 15psi...however now I am going to be running 18psi as a daily and 20psi fo the track...
But the gauge only goes up to 20psi...
My question: is this ok? Or do I need to get a gauge that goes higher? And if so how high?
Hrm intresting, all they change is the background image, other than that there identical
- Dell'Orto
- ** Moderator **
As long as its accurate and your boost control is sweet, then why bother?
why you need higher if your going to be running 20psi? i have a 20psi guage because i run up to 20psi, with the external and my boost controller i'm not worried about spiking over that at all. if your wastegate control is crap and spikes, it might be worth while
the only reason i'm changing mine to a 30psi one is because i'm plannng to run 25psi
- Santa'sBoostinSleigh
- ** Moderator **
- Contact:
as you would expect, ones in bar and ones in PSI is it not?
and no8, personally i would get one that went ~5PSI higher than what you intend to run - gives you some leeway
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
- Mr Revhead
- SECURITY!
- Contact:
Adydas wrote:Just get and use a AVCR, Does control as well as a nice digi display.
Ummm why spend hundreds on an Apexi boost control when he has a Link solenoid doing all that already? Which may be a denso unit depending which he has. He only needs a gauge that meets his needs, which is one which reads over 20psi. A mechancial VDO units can be had for under $100, hundreds less than buying a complete new boost control system.
Supra MKIV Aerotop (UZA80FTE conversion) STATUS: 3 months to go!
Nitrous is like a hot chick with a STD..... you know you wanna hit it, but you are afraid of the consequences.....
Free online business and reporting tools visit www.e-solver.com
Adydas wrote:its just another option, it seems like thats what hes after its not like i expect him to buy the defi guage i posted up either.
Ah ok, well you did tell him to get the AVCR thats all... I dont see why he seems to be after a new boost control system when he has one bt just runs out of range on the gauge he has...
Anyways, here is a source I have often for gauges. Boost gauge linked.
http://www.egauges.com/eg_typeI.asp?Typ ... l&Manf=All
real gauges count is kPa's
- QikStarlie
- Toyspeed Member
- Contact:
no_8wire wrote:Running a TD05h off a Evo4...with internal, and boost control via a link solenoid....
I reckon that'll spike a fair bit. The internal wastegates on those arent great.
Get a gauge that reads to say 2 bar for peace of mind and as kris said, set the boost limiter in ya link for safety
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
