Bang bang on a ceramic CT20B?
Postby RedMist » Tue Dec 19, 2006 6:21 pm
Need to know if anti-lag will destroy the ST205 non WRC turbo.
Well its gotta sound like a rally car doesnt it?
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby Dell'Orto » Tue Dec 19, 2006 6:28 pm
Yes yes it will, and in fairly short order too.
Postby RedMist » Tue Dec 19, 2006 6:33 pm
Figured
RedMist
Postby Dell'Orto » Tue Dec 19, 2006 6:35 pm
Make Toyota sponsor you a new WRC spec CT20B :D
Postby flygt4 » Tue Dec 19, 2006 6:37 pm
haha that would be cool to see. if you want antilag use something cheap and readily available like a tdo5 :wink:
flygt4
Postby RedMist » Tue Dec 19, 2006 6:52 pm
I'll have to check my regs again in regards to turbo replacement. It might be that I have to retain the existing turbo, in which case I'll try to get in a WRC engine and tranny (need a spare). That way I have all the bang bang hardware and the water injection stuff as well. Unless I can find one thats been destroyed, such that I can steal all the goodies from.
RedMist
Postby RedMist » Tue Dec 19, 2006 6:53 pm
Mmm, Boost wrote:Make Toyota sponsor you a new WRC spec CT20B :D
WARRICK YOU LISTENING!
RedMist
Postby Al » Tue Dec 19, 2006 8:36 pm
You might want the TTE version for longevity. Ask them for some race fuel while you are at it.
redmist wrote:It might be that I have to retain the existing turbo, in which case I'll try to get in a WRC engine and tranny (need a spare). That way I have all the bang bang hardware and the water injection stuff as well.
You might also find the factory antilag is inactive and missing components.
Al
Postby RedMist » Tue Dec 19, 2006 8:51 pm
Al wrote:You might want the TTE version for longevity. Ask them for some race fuel while you are at it.
Some of the airfeed tubes are sealed. And the trigger is missing from the ECU. It shouldnt be that hard to re-enable. Considerably easier than re-creating the entire system.
RedMist
Postby Mr Revhead » Tue Dec 19, 2006 9:30 pm
bugger, steel WRC turbo went up over $500 in price a few months ago....
Postby RomanV » Tue Dec 19, 2006 10:04 pm
Mr Revhead wrote:bugger, steel WRC turbo went up over $500 in price a few months ago....
likely story. :lol:
Be nice... smartarses need discounts too
Postby Mr Revhead » Tue Dec 19, 2006 10:11 pm
sad but true
i dont think i can even do them for $2k now :(
Postby Prymal » Tue Dec 19, 2006 10:42 pm
Not only will you need to re enable all the goodness of valves and hoses in the bay , and exhaust manifold to suit ( theres a line of air hoses tapped in underneath it - you can see them on mine still ) ,
youll need the proper trd/tte ECU , not a standard group A one , and also , if you dont want to be chewing turbo's and destroying blocks , the proper WRC items of turbo and block - I had sorta looked into this for My Group A WRC and found it to be pointless.
AN Aftermarket ECU ( like say motec ) enable it if you set it up correctly but you still need the mechanical hardware to back it up to stop it destroying itself , and a budget to match
They didnt use the ct20B on the WRC car by memory but another rarer hybridisation
one of these turbo's was available in OZ recently - its still a CT variant but cannot recall the number
Your welcome to gaze over all the associated bits on my group A if you wish - everythings still intact and in factory condition bar my turbo
Prymal
Postby RedMist » Tue Dec 19, 2006 11:28 pm
classique71 wrote:Not only will you need to re enable all the goodness of valves and hoses in the bay , and exhaust manifold to suit ( theres a line of air hoses tapped in underneath it - you can see them on mine still ) ,
Thanks for the offer, however you're in Auckland, I'm in CHCH. In regards to aftermarket ECU, I'll either go Link G3 or if I need to go individual cyl trim for pots 2 and 3 I'll go the Plus G2
RedMist
Postby Phothog » Wed Dec 20, 2006 8:28 am
Mr Revhead wrote:sad but true
i just sold the only captive Steel CT20b in NZ :(
But we do have New Steel Shaft & wheel assemblies in stock, so we can rebuild yours.. :D the wheels are actulaly not badly priced...
PM or E-Mail me for prices...
____
Chris
Phothog
Postby mister2 » Wed Dec 20, 2006 10:09 pm
What type of antilag are you talking? Not all are bang bang... Link Group A style isn't either, more of a whoooooooooooooshpshpshpshpshsphspshpshsh :D And that won't need all the valves and plumbing to the exhaust manifold either, just a decent sized throttle bypass.
Any antilag sustained will kill turbos, it is just the heat side of things that does it.
Nick
www.nzefi.com
4WD Dynapack Dynamometer.
Link, MoTeC, Greddy, Power FC sales support and tuning.
Weapon of Choice: 1992 NSR250 SE
On hiatus, current location: Cambridge, UK
mister2
Postby Phothog » Thu Dec 21, 2006 5:11 pm
classique71 wrote:They didnt use the ct20B on the WRC car by memory but another rarer hybridisation
i nicked these off a auction on Ebay... a Brand new WRC Turbo
Phothog
Postby RedMist » Thu Dec 21, 2006 5:43 pm
mister2 wrote:What type of antilag are you talking? Not all are bang bang... Link Group A style isn't either, more of a whoooooooooooooshpshpshpshpshsphspshpshsh :D And that won't need all the valves and plumbing to the exhaust manifold either, just a decent sized throttle bypass.
Nick
Nick, thanks for that. Its just a matter of keeping the thing spooled. Some of the 185 rally cars in CHCH with 205 running gear have had greater sucess going back to a CT26 because of spooling issues.
I think I have managed to get hold of an exhaust manifold from a 205 WRC and the associated bang bang kit. I'm currently tossing up wether or not to run rich throughout the map with a LEM 3 or spend the little bit extra and go Plus G2 and wet up (with individual cyl trim)2 and 3 to stop ring landing damage. This will also determine which mode of antilag I go for, Mode 1 in the G3 or Mode 1 or 2 with the G2 plus. Whichever route I go for I had hoped that I could keep exhaust temps down a little with the air bypass.
As you can see..... I need to dedicate myself to researching a bit more, especially on the turbo side as I've only just started down the compressed racing route.
RedMist
Postby mister2 » Mon Dec 25, 2006 2:18 am
The only way you will be able to tell if cyl 2&3 are lean (er than 1&4) is with individual EGT probes. I would cross that bridge when you come to it. To be honest leaning out a little isn't what breaks ring lands, that is detonation - but anyway if you really got keen and found that there was bad cylinder distribution you could always use the two drives of the LEM and trim them out.
How does the WRC antilag gear work? Is there much point in using that style of system? Is it even compatible with the Link stuff? The Link antilag works on the principle of diverting more air through the motor (either through throttle stop [Group N] or bypass valve [Group A]) and retarding timing, not injecting air and fuel into the exhaust manifold like it sounds the WRC stuff does.
Nick
www.nzefi.com
mister2
Postby Akane » Mon Dec 25, 2006 7:24 am
Phothog wrote:i nicked these off a auction on Ebay... a Brand new WRC Turbo
Does it come with the dodgey restrictor?
Users browsing this forum: Bing [Bot], Google [Bot] and 12 guests
