removing ae92 dash cluster
Postby Cakky » Fri Dec 22, 2006 5:22 pm
ok managed to get all screws off and have cluster loose, but can't pull out or move far enough to look in behind it, whats the trick here to getting this sucker out?
i need to get rid of my 106km/h speed chime Sad
Cakky
Postby Santa'sBoostinSleigh » Fri Dec 22, 2006 6:29 pm
its a b!tch
mines half off, i got grumpy and gave up
another reason why the racecar isnt progressing
lol
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby Cakky » Fri Dec 22, 2006 7:26 pm
lol gutted. guess i'm heading up the line tomorrow with the sounds cranked up lol.
Cakky
Postby big_boy » Fri Dec 22, 2006 10:18 pm
disconect the spedo under the bonnet
big_boy
Postby SpeedRacer » Fri Dec 22, 2006 10:32 pm
while where talking about behing the speedo cluster, which wire goes to the tacho? need to hoock mine back up :?
Sinister Sleeper 35
SpeedRacer
Postby Ae92typeX » Sat Dec 23, 2006 12:13 am
should be able to angle it out one side (i think the left from memory) so you can put a hand around the back and take off the looms(blind). Not too hard really, I didit heaps on my old 92. Once off, the chime is obvious and justnscrews.
Ae92typeX
Postby gordon77 » Sat Dec 23, 2006 9:26 am
yeah its piss easy once u figure it out - disconnceting the spedo cable just behine the inlet manifold helps heaps. the loom has enough slack to allow you to angle it out towards the passenger seat then just shove ur hand in thur and pull the connectors out. i could have mine out in about 1 min once id done it a few times :)
What is RR?
gordon77
Postby Cakky » Sat Dec 23, 2006 3:45 pm
got it!!!
just takes heaps of perserverance and patience, both of which I usually lack, undoing the speedo cable helps heaps once you undo that you can pull it far enough to see all the loom clips and undo them all, got speed chime out, putting clips back in is a little harder, just need to feel around a little bit...
stupid me though, put it all back together and speedo and rev counter were not working :(
note to anyone that does this, please remember to replace the screws that held the two wires that are connected to the chime to the cluster, if you do not place these back in the circuit is not complete and nothing will work, as I found out the hard way :D and don't forget the gold coloured screw on the left hand side of cluster when putting back in I would say thats the most important one as obviously completes circuit..
everything works sweet now, no more chime :D
Cakky
Postby Crampy » Sat Dec 23, 2006 8:22 pm
I've taken the speed chime out of my AE92 as well. Although it came on and off at random times, it was still damn annoying.
The speedo drive took a bit of a hammering before I realised I needed to disconnect it from uinder tha bonnet :lol: Oops, my bad.
Crampy
Users browsing this forum: Bing [Bot], Google [Bot] and 6 guests
