crshbndct wrote:7a-fe will work. not a cheap exercise. unless you can do most of the work your self. you will also lose some of the revvability unless you get stronger internals.
for a much more powerful and drivable car, chuck the black tops, get a silvertop, and fit 4agze pistons to it, and put on a small turbo.
BLACKTOP_WAGON wrote:THANKS that was alot of help it wont be as hard as i thought it might be with the honda they had to modify the block and head for the oil galleries to match each other would i be able to turbo this 7age, i guess i would need to get new pistons and conrods and computer anyway thanks one more question would the sensors for the 7afe block match the blacktops computer or do i need a new computer
BLACKTOP_WAGON wrote:so do these sensors need to be changed what would i need to do
BLACKTOP_WAGON wrote:you known what go $&#$% yourself i just tying to change my wagon and $&#$% heads like you just come along and act all cool cause you think you know everything $&#$% off
