gaskets and sealant, sumps
Postby bluemaumau » Sun Dec 24, 2006 5:49 pm
ok today i removed my sump, baffle plate and pickup.
there were gasket/seals attached to most things and goo around the outer lips of everything.
can anyone give me the technical names of all the gaskets/seals, so i can order them easily?
also what type of goo/sealant is used, so i can pick soemm up.
ae92 afm 4agze
cheers all
Postby ollieboy » Sun Dec 24, 2006 5:52 pm
I'm not sure what sealant they use from factory but when I put my Cressida engine back together I used RTV and that seems to have lasted.
ollieboy
Postby bluemaumau » Sun Dec 24, 2006 5:53 pm
Postby Bling » Sun Dec 24, 2006 9:01 pm
I recall seeing someone say in the thread you can get toyota black sealant. I'm sure a layer of that would sort most seals. Tis factory used on some parts anyway including some sumps etc
Postby matt dunn » Sun Dec 24, 2006 10:45 pm
The sump sealant is quite important as they have no actual sump gasket.
Postby bluemaumau » Sun Dec 24, 2006 10:47 pm
is there no actual seal somewhere inbetween block, baffle plate and sump?
Postby no_8wire » Sun Dec 24, 2006 10:52 pm
nope only the sealant goo...makes it easy, can you imagine trying to align a gasket to clear all the sump bolt holes!
8O
no_8wire
Postby bluemaumau » Mon Dec 25, 2006 12:09 am
thats weird i peeled of a seal type thing. aswell as the sealant :?
Postby CozmoNz » Mon Dec 25, 2006 1:37 am
not confused with the auto tranny sumps?
Ive never seen one on an engine sump....
Rayne For President!
CozmoNz
Postby Ae92typeX » Mon Dec 25, 2006 8:04 am
Ive seen gaskets on many car sumps (lining up the holes aint too hard, but helps to have engine upside down lol), but never on any toyotas Ive worked on. No reason you couldnt use one, but as above, just the sealant works fine.
I have normal rtv gasket silicone on mine. No issues for the year the engines been together.
Ae92typeX
Postby CAMB01 » Mon Dec 25, 2006 8:27 am
The gasket set i got for my 4agte came with a cork sump gasket.
I aint gonna use it, as im just going to use sealant, but it was in the gasket set.
It was just a gasket set for a 4age/gze
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby Psycho_Dad » Mon Dec 25, 2006 5:51 pm
CAMB01 wrote:The gasket set i got for my 4agte came with a cork sump gasket.
the gasket set i got for my afm ze from toyota had no cork sump gasket... did you go genuine parts??
Psycho_Dad
Postby CAMB01 » Mon Dec 25, 2006 8:11 pm
nah mines an ACL gasket set
CAMB01
