the clutch was better than i expected , had bugger all meat left, probly ~ 15% , thrust bearing was well rooted and the pressure plate had some slightly interesting glazing on it. flywheel apears to be in pretty good nick tho. just after some opinions from people who have pulled/seen a few rooted clutchs etc as to whether this glazing is normal, what may have caused it etc.
the offending PP , note burnt spots @ 2 and 8 o clock, appears to be a standard 4agze plate
closeup
turns out i had an exedy disc in there
wasnt quite to the rivets
im sure you might have seen worse, but any thoughts on what may have caused the burnt spots?
