Good Engineer in ChCh required
Postby Dunny » Tue Jan 02, 2007 7:53 pm
Can any recommend a good engineer in Christchurch? Someone that's got a big arse lathe?
Dunny
Postby Elmo » Tue Jan 02, 2007 8:34 pm
Royce Clive, I dont know if there lathe is big enough, but they do good work. in the shops behind Beaurepaires at sockburn roundabout.
Elmo
Postby Dunny » Wed Jan 03, 2007 9:00 am
ok thanks I'll give them a bell - I'm basically wanting to be able to spin a strut tube, so the bed has to be pretty deep
Dunny
Postby Logan » Wed Jan 03, 2007 11:55 am
they have jigs for doing that. If you are shortening tubes and re-threading, another option is you can buy a threade sleeve type thing from autolign such that you just cut the strut, and weld this but on the top, its what i used and works mint. Then again i have no idea what ur actually doing :P
SR Sold. Onto Other Things
Logan
Postby Dunny » Wed Jan 03, 2007 3:24 pm
Yeah thanks - you're totally on the wrong track
But anyway all sorted have found a guy to do it so hopefully all will turn out well.
Dunny
Return to Christchurch / Upper South Island Region
