flygt4 wrote:it makes the same power as a lot of b18 turbo setups, ive had a best of 218kw atw.A B series with a decent turbo+ecu would make around the same power @ 10-12psi where i require 20psi due to the difference in compression.
Akane wrote:No, no and NO.
All this PSI talk makes me want to hurt myself (and then hurt you).
Vtax engines make more power at the same "PSI" level is due to their high flowing head, their lift and valve area is HUGE comapred to 4AGE's and the like, hence less restrictions, flowing more air, and the boost gauge registers less boost.
Don't talk in PSI unless we're comparing identical setups, please talk in lbs/min.
My very uneducated and pixel-mechanic like guess is that most vtax turbo engines are tuned with loads of fuel and a lot of timing retard to combat detonation, they're OK engines but physics is physics, if the static compression ratio is sky high, you will get detonation. Dump heaps of fuel to compensate is what most of them do. Try get a 1.8 vtax to flow 35lb/min of air and run 12.5:1 with stock internals then we'll talk.
Akane wrote:flygt4 wrote:it makes the same power as a lot of b18 turbo setups, ive had a best of 218kw atw.A B series with a decent turbo+ecu would make around the same power @ 10-12psi where i require 20psi due to the difference in compression.
No, no and NO.
Not a dig at you flygt4 but a lot of kiddies always say "I makez mad powahs with teh t3/t4 at 25psi au! mad vtax!"
No, no and NO.
Lith wrote:Agreed. Sortof why I was inclined to say why bother? If you start modding them to the nTH degree to match or surpass the others strengths while retaining or improving its own advantages then you end up in a situation where its just a fully potent 1600cc and instead of comparing it with a stock 1600 - you are comparing it with other worked motors.
Getting a stock 4AGE and camming/porting/raising the compression on it and then making more power than a stock B16A would hardly be proving anything other than the fact that you can make more power by spending money.
regamaster wrote:there are some vtec turbo b16a's running forgies etc, but due to the lack of traction stuck in the 13's, maybe low 13's, when nicely modded N/A ITR's are doing higher 13's, around 13.7's.
there is also crazy standard blocked turbo B16A's doing 12's, and also a B18BT 1800 dohc non vtec turbo integra without forgies doing high 12's also.
[b|indsp0tt] wrote:My boss's old integra was running a Blox manifold with rebuilt r32 skyline turbo,made 180kW @ the wheels @ 8psi.This was on a b18b (1.8ltr DOHC non vtec),these motor's are alot better for turboing as they have a lower compression (9.6:1) from what I remember.
EVLGTZ wrote:[b|indsp0tt] wrote:My boss's old integra was running a Blox manifold with rebuilt r32 skyline turbo,made 180kW @ the wheels @ 8psi.This was on a b18b (1.8ltr DOHC non vtec),these motor's are alot better for turboing as they have a lower compression (9.6:1) from what I remember.
That was my mates old car before it was sold to your boss. Very basic setup with good power from a non-vtec motor.
vvega wrote:the b16a IS a FACTORY worked engine
in fact its no diffenet to comparing a b16a to a atlantic engine
v
