cam covers/ cams
cam covers/ cams
Postby bluemaumau » Fri Jan 05, 2007 5:57 pm
ok ive been searching for around half an hour, and im probley not puttin in the right keywords.
1.how the frig do i get my cam covers off, the engines completely stripped back (p/s, inlet, exhaust etc) except for the CAS.
ive undone the black part in the middle and the 4 nuts on each cover, still wont budge, is there a trick?
2. cams, how do you remove the cam wheel/gear from the shaft? the timing belt is off.
cheers, im probley missing something real obvious, but meh im on holiday 8)
Postby Silent Knight » Fri Jan 05, 2007 6:10 pm
What sorta engine?
Normally to remove the covers you just remove the outside bolts around it and maybe a couple that might be down the middle between the cams. Once you remove those along with any hoses etc that attaches to the cover it should just pop off.
The cam wheel should have a bolt in the middle which you need to crack first before you can undo it. Good luck doing that with the belt removed however. :P
Put the belt back on and then put a big power bar on the crank to stop it from moving, then use another power bar to crack the bolt on the wheel. Otherwise a rattle gun should do the trick.
Silent Knight
Postby 20v_rollaboy » Fri Jan 05, 2007 6:12 pm
Pry it off with something sharp (aka flat blade screwdriver lol). Probably just the sealant holding it on.
As for the cam wheels, you could take the cams out and put them in a vice, and then take the wheels off.
20v_rollaboy
Postby bluemaumau » Fri Jan 05, 2007 6:12 pm
bigport 4agze
swt thanks
ill put the belt back on
its on a engine stand so all pretty easy.
now these blooooddy covers!
ive tried bashing em and everything!
Postby Silent Knight » Fri Jan 05, 2007 6:13 pm
If violence doesn't work then you're obviously not using enough of it...
Silent Knight
Postby bluemaumau » Fri Jan 05, 2007 6:15 pm
great call, ill just turn korn up, whilst doin it, thanks all
Postby no_8wire » Fri Jan 05, 2007 6:16 pm
As above...
The middle bolts, then the four bolts on each cover. Try to give it a whack sideways with a bit of timber and then lift it off...
Cam wheels
There is a hex in the cam which a 1" wrench will fit over. stick your wrench on it and at the same time as holding that undo the cam wheel bolt
no_8wire
Postby thaphatty » Fri Jan 05, 2007 7:44 pm
your ALL wrong :D
theres little oil seals under each rocker cover nut. make sure theyre all pryed off, sometimes need a minature screwdriver to get in there, otherwise the covers will not budge no matter how hard you bash them.
thaphatty
Postby IH8TEC » Fri Jan 05, 2007 8:31 pm
and to get cam wheels off, take the cam covers off :lol: then get a bic open end spanner, 2... mm and put it on the bit where it goes in the middle of the cam, hold that, and crack the one on the cam wheel
Postby bluemaumau » Fri Jan 05, 2007 9:09 pm
sweet as i used SKs method, worked a treat.
now having trouble gettin the cam retainers(dont know the technical term) off, the 10mm spanner of doom isnt even worken
Postby no_8wire » Fri Jan 05, 2007 9:32 pm
Try a single hex long socket...and then you can really put some force into it with out fear of rounding the bolt
no_8wire
Postby Crampy » Fri Jan 05, 2007 9:40 pm
bluemaumau wrote:sweet as i used SKs method, worked a treat.
Spanner!!! Ouch man.
Get a power bar and a good socket and put some torque into it.
Crampy
Postby bluemaumau » Fri Jan 05, 2007 9:41 pm
yea i dont have one of them, might make a trip to repco tommorow
Postby bluemaumau » Fri Jan 05, 2007 9:43 pm
my socket isnt long enough to reach past the four studs that hold the covers on, dammit
Postby RedMist » Fri Jan 05, 2007 9:43 pm
thaphatty wrote:your ALL wrong :D
Thats the way, remove the seals first.
I hope you haven't distorted the covers by bashing them.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby bluemaumau » Fri Jan 05, 2007 9:46 pm
nah i didnt bash em cause i knew it wasnt the way, just pryed em off
Postby no_8wire » Fri Jan 05, 2007 9:54 pm
bluemaumau wrote:my socket isnt long enough to reach past the four studs that hold the covers on, dammit
Need to get one of those long/deep sockets...think about $8- $10 from repco
no_8wire
Postby bluemaumau » Fri Jan 05, 2007 10:57 pm
swt cheers rory
Postby Crampy » Sat Jan 06, 2007 8:29 pm
yep, those ones are a pain in the ar$e!
Crampy
Postby bluemaumau » Sat Jan 06, 2007 8:32 pm
the worst thing is that in repco the only deep socket 10mm is in 3/8 drive so you have to buy a 1/2 -> 3/8 adapter :evil:
Users browsing this forum: Bing [Bot], Google [Bot] and 3 guests
