ae92 dash tacho wiring
Postby SpeedRacer » Fri Jan 05, 2007 8:16 pm
hey,
which wire do i splice on my cluster to get my tacho working again?
EDIT:: haha its an ae92 trueno running a link ecu :oops:
Sinister Sleeper 35
SpeedRacer
Postby SpeedRacer » Sat Jan 06, 2007 6:20 pm
bump
even if some one could tell me how to figure out which one it is?
Sinister Sleeper 35
SpeedRacer
Postby soopachargen » Sat Jan 06, 2007 6:35 pm
is it a non gze dash with a gze twin coil setup??
When in doubt, down and out.
soopachargen
Postby SpeedRacer » Sat Jan 06, 2007 6:55 pm
nope just a standard gt apex with dizzy
Sinister Sleeper 35
SpeedRacer
Postby Paulio » Sun Jan 07, 2007 11:45 am
im sure its green?? maybe thats the tacho one.
Paulio
Postby Caveman » Sun Jan 07, 2007 6:17 pm
IIRC it comes from the ignitor, and is common with the IGN- signal from the daignostics panel, its a black wire.
AW11 Track Toy
Formerly known as 1998
Caveman
Postby SpeedRacer » Sun Jan 07, 2007 8:30 pm
black/orange sound familiar?
Sinister Sleeper 35
SpeedRacer
Postby SpeedRacer » Sun Jan 07, 2007 9:24 pm
also is a tacho essential for dyno?
Sinister Sleeper 35
SpeedRacer
Postby matt dunn » Mon Jan 08, 2007 7:36 pm
SpeedRacer wrote:also is a tacho essential for dyno?
not with a link as the will just get rpm off the hand controller or laptop they will use.
Depends on how it is wired.
If they have used most of the OE loom and just adapted on the link and igniter etc etc onto the appropiate places in the loom,
( which is quite likely)
the easiest place is just go to the old igniter wiring.
There would have originally been 5 wires, and now they will only be using 3 or maybe 2 as none of the 5 are earth.
You need to join the one that was labelled EXT on the old igniter and join it to the coil -ve.
OR failing that run a wire from the IG- in the diagnostic socket to the coil -ve.
Matt
Postby SpeedRacer » Mon Jan 08, 2007 8:30 pm
ok, wiring in engine bay is completely new. also will having no cluster affect starting? becasue now it wont start :evil:
Sinister Sleeper 35
SpeedRacer
Users browsing this forum: Google [Bot] and 1 guest
