i've just run into a problem id never seen before. we just got new clutch master cly and the slave cly for a ae86 that didnt have any. the two parts shops i went to say its 100% the oem replacement parts. BNT and butlers auto mart, both really good shops. they gave me a
15.87 = 5/8" bore master (74967365)
and 20.64 = 7/8" bore slave
(^ does that sound like the master is too small for the slave to you!!!)
the problem is the slave does not move far enuf to release the clutch.
questions.
1, do those bore sizes sound right? for stock ae86
2, if they are right what could be causing this? we bleed it several times to make sure there wasn't air bubbles.
3, we tried fitting a 3/4'' slave and it worked very well. but the slave is the wrong shape, is there any other 3/4" slave thats the same shape as ae86?
Im running nite parts 4a>w5* bell housing. same fork and carrier as came with box and pivot nob thing.
ae85 pedal box converted to hydro.
please any help will be greatly appreciated. i need to move the car out of my mates garden very soon.
