blown head gasket
blown head gasket
Postby Mike- » Wed Jan 10, 2007 1:12 pm
is this normal? ive had a blown head gasket but it never looked this whorey. wat do yall think?
btw its a 4k
Mike-
Postby Leon » Wed Jan 10, 2007 1:30 pm
that's pretty standard "water got into my oils" symptom.
Postby Mike- » Wed Jan 10, 2007 3:59 pm
im having trouble getting the head off now, all 10 head bolts are out, manifolds are off, thermostat off, and ive tried sticking a screw driver in the slots and all it got was a little bit of water seepage, and it got a few whacks with the rubber mallet but still not budging. any ideas?
Mike-
Postby Adydas » Wed Jan 10, 2007 4:26 pm
A crowbar? or just leaver it
Adydas
Just keep trying bro
Postby TOYROTA » Wed Jan 10, 2007 4:27 pm
keep at it they are stubborn sumtimes.
or you could hit it harder
Curre3nt rides-
1982 starlet kp61 4 door (in panel shop getting bare metal resto)
1980 tt132 corona wagon 3t t40 (daily doomsday machine)
TOYROTA
Postby Arthanon » Wed Jan 10, 2007 4:52 pm
Just done the head on my old mans Surf.
We had to leaver it off with a crowbar. The locating pins were quiet tight.
Current Ride: 1998 GT Caldina 3S-GE BEAMS Goodness
Previous Ride: 1994 Curren 3S-FE Not so Goodness
Arthanon
Postby Dell'Orto » Wed Jan 10, 2007 4:56 pm
Just spray a little CRC down the bolt holes, and give it a whack with the rubber mallet, it'll free up. Wouldnt recommend using a crowbar unless you're planning on machining it!
Postby Mike- » Wed Jan 10, 2007 5:38 pm
one of the head bolts has snapped off, it was rusty as, its about 5-6mm into the head from the block side, how can i get this out?
Mike-
Postby flygt4 » Wed Jan 10, 2007 5:40 pm
easy-outs?
flygt4
Postby Punter » Wed Jan 10, 2007 5:46 pm
Is the head threaded??
You should be to pull the head off still.
Punter
Postby Dell'Orto » Wed Jan 10, 2007 5:49 pm
Yeah just get the head off and use vicegrips to pull the broken one out.
Postby Mike- » Wed Jan 10, 2007 7:00 pm
so the head aint threaded? its sticking on something around there
Mike-
Use
Postby andyztouring » Wed Jan 10, 2007 7:48 pm
Use a block of wood and a LARGE hammer ,tap at bolts on side of head from underneath,can be stubborn to come off.
andyztouring
Postby thaphatty » Wed Jan 10, 2007 9:37 pm
Rocker cover looks very similar to the forklift headgasket i've been doing at work over the last couple days
Most likely headgasket, an array of other possible things mind.
thaphatty
Postby Mike- » Wed Jan 10, 2007 9:51 pm
whats been going on here? there where shards of metal sticking out of both parts, doesnt look too good
Mike-
Overheated
Postby andyztouring » Wed Jan 10, 2007 10:00 pm
Most likely badly overheated and sitting with water in bore. Scrap engine and get another good one.
andyztouring
Postby Mike- » Wed Jan 10, 2007 10:04 pm
the engine ran sweet on the way home with a blown head gasket and didnt overheat, im not sure what happened before i got it tho. does everyone agree the engines rooted or will the 4k live another day?
Mike-
Looks
Postby andyztouring » Wed Jan 10, 2007 10:14 pm
Looks like the bore is severely pitted ,only a rebore and oversize pistons will fix that engine.
andyztouring
Postby Mike- » Wed Jan 10, 2007 10:17 pm
pitted as in lots of little chunks out of it?
Mike-
The top photo
Postby andyztouring » Wed Jan 10, 2007 10:21 pm
The photo of the bore show pitting as big chunks out of it.Should be reasonably smooth with slight honing marks.Appears to be caused by sitting around with water in the bore .
andyztouring
