lsd question!
lsd question!
Postby slighty_looney » Sat Jan 13, 2007 2:09 pm
I was wondering if it was possable to use a lsd from a mr2 and put it in my 94 celica 3sge gearbox ??
FC3S
Robinson Steel Fabrications
Current Ride: 88 rx7
Project: viewtopic.php?t=88412
Discussion: viewtopic.php?t=88413
slighty_looney
Postby strx7 » Sat Jan 13, 2007 6:01 pm
non turbo.....yes, turbo.....no.
Some curren/Celica S54's have LSD apprently.
C series LSD's fit the S series boxes.
Postby TRD Man » Sat Jan 13, 2007 9:11 pm
Actually the reverse may apply.
I can't tell about OE equipment but in TRD language the 94 Celica (ST202) shares the same LSD as post 91 MR2 turbo.
TRD Man
Postby Mr Revhead » Sat Jan 13, 2007 9:52 pm
to clarify:
st202 celica from 10th 93 with superstrut uses same lsd as gen 2 (12th 91 on wards) sw20 turbo. st206/7curren with superstrut applies from 2nd 94.
Postby Mr Revhead » Sat Jan 13, 2007 9:56 pm
i suspect your wanting to put an LSD in the front of your GT4?
i beleive you can, but i cant confirm it.
they box internals are pretty simllar to the sw20 turbo, but im not sure how the transfer will effect the diff
Postby Dell'Orto » Sun Jan 14, 2007 4:25 pm
He has an ST202 with a turbo'd 3SGE. I think it might have an E series box.
Postby TRDGT4 » Sun Jan 14, 2007 5:45 pm
yip its an e series box
TRDGT4
Postby Boosted_162 » Sun Jan 14, 2007 5:58 pm
Really? I thought 202's used a S series box? And i didnt even know there was a FWD E series box bar the GTZ one.
Or just convert a E153 :wink:
Postby slighty_looney » Sun Jan 14, 2007 9:57 pm
Boosted_162 wrote:Really? I thought 202's used a S series box? And i didnt even know there was a FWD E series box bar the GTZ one.
wats a e153? yep its defently a e series g-box
FC3S
slighty_looney
Postby Boosted_162 » Sun Jan 14, 2007 10:05 pm
E153 is a turbo MR2 box. Early ones were optional LSD, but later ones were standard. Alot more common than FWD celica LSD boxes. Only thing you need to do is change linkages with your current box.
Writeup is in FAQ, and on www.fasterthanjesus.net
Postby slighty_looney » Mon Jan 15, 2007 5:41 pm
Boosted_162 wrote:E153 is a turbo MR2 box. Early ones were optional LSD, but later ones were standard. Alot more common than FWD celica LSD boxes. Only thing you need to do is change linkages with your current box.
What year mr2 turbo would i get that g-box out off and whats the g-box number ?
FC3S
slighty_looney
Postby slighty_looney » Mon Jan 15, 2007 10:11 pm
bump :?:
FC3S
slighty_looney
Postby slighty_sykotic » Mon Jan 15, 2007 10:28 pm
Its a E153.
And its in early or later sw20 turbo mr2s. The early ones MAY have a lsd, but the late ones SHOULD have one.
Doesnt matter what year as much, just as long as its lsd, and of course, low kms is better.
--Sykotic
slighty_sykotic
Postby Boosted_162 » Tue Jan 16, 2007 12:45 am
Taken from FAQ
fivebob wrote:LSD was standard on all turbo SW20s from Dec '91 (Chassis# > 59266).
And link to writeup on converting E153
viewtopic.php?t=41540
EDIT: Another good thread in FAQ
viewtopic.php?t=32117
Postby pureadrenalin » Tue Jan 16, 2007 12:34 pm
I got an E153 in my garage with crapp syncros, and no lsd.
But theres an lsd sitting on my bench. :)
pureadrenalin
Postby slighty_looney » Wed Jan 17, 2007 7:34 pm
Hey could i get that lsd from that box and put it into my box???
FC3S
slighty_looney
Postby slighty_looney » Thu Jan 18, 2007 4:49 pm
bump
FC3S
slighty_looney
