Indicators wont work on caldina gtt
Postby gleem » Tue Jan 23, 2007 5:29 pm
Hi there, recently my idicators have stoped working and when i replace the fuse they work for about 2 clicks then blow, i noticed it a little while after we installed the wiring for a sub and amp if that helps.
I have been to an auto electrition and they quoted me far too much imo for what shouldnt be too much of a job for someone who knows a bit in this field.
I don't know much when it comes to car electronics but if anyone who knows there stuff about car electronics in toyotas in the auckland area and could prehaps help me fix it i would be willing to pay a bit of cash
also a friend who may be able to help said he needed an electrical wiring diagram for the car is this what i need here --> http://www.users.on.net/~fivebob/Pages/pins.xml
Anyhelp appreciated!
gleem
Postby big_boy » Tue Jan 23, 2007 6:25 pm
that wireing digram is engin not chassie so no not what you want
what happens if you unplug the head unit @ the plug at the back also do you have a muilty meter as i can give you a couple of tests to try if you do
for sale EE90
big_boy
Postby gleem » Tue Jan 23, 2007 8:01 pm
yes i can get my hands on a multimeter what should i test
gleem
Postby big_boy » Tue Jan 23, 2007 8:26 pm
take out all the bulbs then test voltage accross
battrie votlage
now turn the key to on
then test
earth pin on one plug - earth on battrie
postive- postive on battrie
now turn left on & test
(on a left side plug)
now turn right on & test
(on a right side plug)
& let us know all the results
this is pridy much the tests that you will be paying for when you take it in
this should show up shorts & bad conections
we will see what happens there first then we will know were to start
for sale EE90
big_boy
Postby matt dunn » Tue Jan 23, 2007 8:56 pm
I am an auto elec,
and even I cant follow WTF you mean in those tests.
Trying to find a short with a multi meter is like trying to find a needle in a haystack with with a telescope.
When you put the fuse in does it blow if you dont turn on the indicators?
No?
Does it blow whaen you turn on the left or the right?
Does it still blow with no bulbs in?
Does it have a trailer plug?
We usually put a short light across the fuse holder so you dont go thru 50 fuses trying to find the fault.
Matt
Postby big_boy » Tue Jan 23, 2007 9:04 pm
thoes tests are what we have always done & prove to work quite well this isent trying to find the short this is trying to find witch wire it is in to start with
for sale EE90
big_boy
Postby gleem » Tue Jan 23, 2007 9:27 pm
it blows with the hazzards left and right, yes it has a trailer plug but that hasnt been touched since ive owned it it doesnt blow when we dont turn the indicators on iirc
gleem
Postby Mr.Phreak » Tue Jan 23, 2007 9:34 pm
I'd check the wiring for the Hazard switch (Assuming you had the dash apart to run RCA's for the amp)
Mr.Phreak
Postby matt dunn » Tue Jan 23, 2007 9:56 pm
gleem wrote:it blows with the hazzards left and right, yes it has a trailer plug but that hasnt been touched since ive owned it it doesnt blow when we dont turn the indicators on iirc
I presume I read that as,
it blows with the hazzards or the left or the right indicator.
If so it is very unusual that it blows on both sides as usually only one side shorts out.
As above, check the hazzard sw is plugged in to the correct place and the wires there are not jammed onto something.
Hey big_boy :lol:
Different people do things different ways.
Wasn't picking on your way of doing it just seems weird to me,
probably like the way I would do some things may seem weird to you.
matt
Postby Caveman » Tue Jan 23, 2007 10:13 pm
Well im not an auto sparky but using a factory earth wire on an aftermarket headunit always sent the electrics up the duff, still dont know why :? On my current car when I tried it, it blew the fuse to all the rear tail lights :oops:
Ive always gone straight from the head unit to the body to earth.
Just a suggestion
AW11 Track Toy
Formerly known as 1998
Caveman
Postby matt dunn » Tue Jan 23, 2007 10:16 pm
Caveman wrote:Well im not an auto sparky but using a factory earth wire on an aftermarket headunit always sent the electrics up the duff, still dont know why :? On my current car when I tried it, it blew the fuse to all the rear tail lights :oops:
Just a suggestion
Thats because you used the Green earth wire that is NOT EARTH !!
common mistake. the green is the tail light feed.
Brown is earth on Toyota.
Postby Lloyd » Tue Jan 23, 2007 10:20 pm
Haha, everyone blames "factory earths" which are never actually an earth
Extremely common issue with people putting headunits in Nissans
Postby Boosted_162 » Tue Jan 23, 2007 11:46 pm
I learnt that the hard way in my first car, an old 1985 mitsi :lol:. Dome fuse blew when i turned the lights on. I thought it was just the pioneer h/u taking too much power :lol:
Postby Caveman » Thu Jan 25, 2007 6:04 pm
Nah was the brown wire, was common with the chassis when tested with a multimeter, so wired it up a boom, blows a fuse when the HD goes on...
Still caused problems, if someone could explain i'd give them a hug
AW11 Track Toy
Caveman
Postby Boosted_162 » Thu Jan 25, 2007 6:57 pm
Caveman wrote:Nah was the brown wire, was common with the chassis when tested with a multimeter, so wired it up a boom, blows a fuse when the HD goes on...
You wired it up to the illumination wire, which dims the HU lights when headlights are on. When the lights are off, its an earth, but when you turn the lights on it's a power source.
Postby Bumpy » Sat Jan 27, 2007 5:56 pm
Gleem,
take your surround off and undo the plugs, and put them in again noting how many wires are in each plug. I had the guys at 4 Guys Auto Barn take out the head unit in my Glanza when I bought it cause I had my own stereo, and they put the plugs back to front, had the exact same problem.
Just a suggestion, brainstorming here ...
Bumpy
Postby gleem » Sun Jan 28, 2007 2:12 pm
Thanks will check that
im offering $50 to anyone in the auckland region that knows a bit about this area that can fix it.
gleem
