Freight/Courier within New Zealand
Postby TOYO-GT-T » Wed Jan 24, 2007 6:56 pm
Can anyone recommend a good freight/courier company which can send car mags within New Zealand at a good price?
I am based in Wellington.
TOYO-GT-T
Postby Bling » Wed Jan 24, 2007 8:09 pm
Search the forum, this question comes up all the time.
I've needed the same info before, did a search and found lots of info.
Postby TOYO-GT-T » Wed Jan 24, 2007 8:28 pm
Will do.
Many thanks.
BC
TOYO-GT-T
asdf
Postby JP0976 » Fri Jan 26, 2007 4:58 am
I work for a company that contracts to a few freight companys and i have one peice of advice.
Package your wheels VERY well.
wrap the wheels in bubble wrap and then cardboard. it may be a hastle but at least you know they will be ok.
JP0976
Postby matt4u » Fri Jan 26, 2007 7:43 am
try toll
SupraCelicaLuxSurf
http://www.offroadexpress.co.nz/images/ ... ui_001.jpg
ADMIN EDIT: oversized image removed
matt4u
Postby TURCEL » Fri Jan 26, 2007 8:45 am
Toll
Mainfreight
PBT
Courierpost
NZ Couriers
They are all as bad as each other..... but Courierpost usually is the best.
TURCEL
Postby Mr Revhead » Fri Jan 26, 2007 9:39 am
screw the lot.....
autoparts express
or
freightlines
Postby Arthanon » Fri Jan 26, 2007 10:08 am
You need to find out if the company you are going to use does residential deliverys.
Mainfreight will not deliver mags to a house. THe person will have to collect them from teh closest depot.
Current Ride: 1998 GT Caldina 3S-GE BEAMS Goodness
Previous Ride: 1994 Curren 3S-FE Not so Goodness
Arthanon
Postby Flunk » Fri Jan 26, 2007 12:00 pm
Arthanon wrote:You need to find out if the company you are going to use does residential deliverys.
Mainfreight will not deliver mags to a house. THe person will have to collect them from the closest depot.
Says who? they did when i worked for them, and ive had stuff delivered to my house by serveral other freight companies. ( by freight, i mean trucking/freight, not courier )
Flunk
Postby gurutasker » Fri Jan 26, 2007 12:04 pm
Flunk wrote:Says who? they did when i worked for them, and ive had stuff delivered to my house by serveral other freight companies. ( by freight, i mean trucking/freight, not courier )
Yes, but generally cheaper for you to drop off/pick up at depot.
:twisted: Wellington's TS Midget :twisted:
gurutasker
Postby Arthanon » Fri Jan 26, 2007 12:48 pm
Says the despatch person I talked to when I wanted to send my mags to auckland...
Arthanon
Postby slighty_sykotic » Fri Jan 26, 2007 1:59 pm
They will if its from a business, but not a personal.
If I wanted to send a bike to a customer, mainfreight will take them to the door, but once I wanted to send one with cash, not on my account (for cashy reasons...), and they refused to send it to the door. Yet, when i said "fine, put it on the account" they are happy to.
$&#$% if I know where.
--Sykotic
slighty_sykotic
Users browsing this forum: Bing [Bot] and 22 guests
