4AGE Bluetop Carby?
4AGE Bluetop Carby?
Postby DriftSpecStarlet » Sat Jan 27, 2007 10:35 am
My mates got a Rolla Wagon with a Bluetop Carby?
How the hell does this work out? Revs to 11k - 12k its beyond me if ya ask...
Anyone elaborate on how it works?
Cheers :lol:,
Ben.
Toyota Celica ST185
Big f'n front mount,
Bodykit (actually looks decent)
Lowerd on blue Springs
T3/T4 Turbo
BOV
All the gadgets!
DriftSpecStarlet
Location: Gisborne, New Zealand, Earth, Universe, Milky Way.
Postby Mr Revhead » Sat Jan 27, 2007 10:41 am
easy
air goes in, mixes wiht fuel, spark applied, BANG engine goes.
:P
some one has put a carb on it
and the rev counter is bust
Postby strx7 » Sat Jan 27, 2007 10:55 am
I think that is the KEY piece
Postby DriftSpecStarlet » Sat Jan 27, 2007 11:40 am
Serious... but... how is it all timed and what not? Im very lost... Carbys dont have ECU's, and the engine is setup for injection which has an ECU... grr
Toyota Celica ST185
T3/T4 Turbo
BOV
All the gadgets!
DriftSpecStarlet
Postby Mr Revhead » Sat Jan 27, 2007 11:43 am
several ways around it
you can buy an ignition only controller
or fit a dizzy of something else
Postby DriftSpecStarlet » Sat Jan 27, 2007 12:14 pm
Ahhk wud it still have the same amount of power?
Toyota Celica ST185
T3/T4 Turbo
BOV
All the gadgets!
DriftSpecStarlet
Postby l1ttle_d3vil » Sat Jan 27, 2007 4:18 pm
carbied 4ages are supposed to have a bit more grunt, but I've never been in one myself to know for sure.
you can run the standard ecu, and basically just wire up the distributor, ignitor and temp sensor I think so it controlls the timing.
otherwise as mr revhead said, you can use modified 4k dizzys or something.
Postby atmosports » Sat Jan 27, 2007 5:36 pm
I'd say depending on carb sizing/brand/filter etc it would be possible to have more power. I'd say that the injected motor would more than like have more low down & mid range torque/power though unless you go a really onto it tuner. Seen it heaps of time with carbs, it easy to get them to make peak power but to get that peak power & produce the goods below that is the harder part, so much so that I even know of people custom making emulsion tubes to suit individual cars now just to get around the limitationsa of stock jets sizes etc.
atmosports
Postby DriftSpecStarlet » Sat Jan 27, 2007 7:49 pm
Wow thats really interesting... Thanks for the Info guys :) ill wait for him to get back from the Nats and then take it for a drive!
Toyota Celica ST185
T3/T4 Turbo
BOV
All the gadgets!
DriftSpecStarlet
Postby SUBARUCONVERT » Mon Jan 29, 2007 1:29 pm
Id say that a full tuned EFI set up vs a full tuned carby the EFI set up will make more power as there is less restriction in the EFI throttle bodys vs the carb's
3ST150
SUBARUCONVERT
Postby thaphatty » Mon Jan 29, 2007 5:08 pm
:roll: define full tune.
its all $$ that is all. the size of your wallet and the speed of your car is directly proportional, reguardless of what setup your using
thaphatty
Postby strap-on » Mon Jan 29, 2007 6:34 pm
Carbs FTW if you want a nice feeling engine,one with good throttle response etc.(and without heaps of serious mods like turbo etc) The latest carbs are almost as good as EFI in terms of efficiency.
strap-on
Postby Mr Revhead » Mon Jan 29, 2007 7:29 pm
ah... im with atmos on this one
Postby SUBARUCONVERT » Tue Jan 30, 2007 7:05 pm
thaphatty wrote::roll: define full tune.
Full tune as everything is optimised for max power on both engines, the only thing that is different is the induction/injection system.
If anyone thinks carbys make for a better feeling engine they are dreaming, i like having a wide powerband
3ST150
SUBARUCONVERT
Postby suberimakuri » Thu Feb 01, 2007 2:44 am
carbs eat dirt.
itbs have all the benefits of carbs plus they are better.
and the weight of fpr sucks. you have dropped your booster and any unused bolts already right?
suberimakuri
Postby shihad » Fri Feb 02, 2007 7:02 pm
whos bluetop carby rolla wagon are u talking bout??? ur not talking bout mine are u?
getting bottled by the friendly Oamaru locals for not doing skids - Coupe Life
shihad
Postby matt dunn » Fri Feb 02, 2007 8:07 pm
At WOT at high RPM, GOOD carbs are almost as good as and EFI setup.
The rest of the time they are not even close.
(Trying driving a car with twin webbers to the supermarket when it's cold for example.)
Postby DriftSpecStarlet » Fri Feb 02, 2007 8:34 pm
Wow heated as... gone from how does this work to debates of which is better and the most powerful :oops: :lol:
And ummm whats your name man, reckon it might be yours? are you Paul Lowery?
Toyota Celica ST185
T3/T4 Turbo
BOV
All the gadgets!
DriftSpecStarlet
Postby matt dunn » Fri Feb 02, 2007 9:07 pm
DriftSpecStarlet wrote:Wow heated as... gone from how does this work to debates of which is better and the most powerful :oops: :lol:
lol
Q. How does this work.
A. Anything can be converted to carbs. Just build a manifold.
A. No ECU, No rev limit.
Postby shihad » Fri Feb 02, 2007 9:16 pm
hes my brother ur talking bout my car and it dont go yet :cry:
shihad
