slighty_sykotic wrote:But yes, it will run. With loom, ecu and map sensor. But you will need the blacktop throttle bodies or will need to modify your ones to get a stable map signal from all 4 throttles.
--Sykotic
slighty_sykotic wrote:You sure about that? Andre from speedtech and Brent from speedworks both reckon that its not stable enough there.
And thats exactly why the blacktop have that mini manifold to collect the signal.
--Sykotic
Users browsing this forum: Majestic-12 [Bot] and 23 guests
