use the blacktop ecu and loom in silvertop
Postby antonio » Tue Jan 30, 2007 9:40 pm
Can you put the ecu and loom of blacktop straight onto the silvertop engine to get rid of the AFM, if can is it easy or will there be modding involved?
AK
antonio
Postby slighty_sykotic » Tue Jan 30, 2007 10:23 pm
Why do you want to get rid of the AFM? Its not a restriction...
You will lose power by going to a blacktop setup with your silvertop motor, even if you do you super cool ram air thing.
But yes, it will run. With loom, ecu and map sensor. But you will need the blacktop throttle bodies or will need to modify your ones to get a stable map signal from all 4 throttles.
--Sykotic
slighty_sykotic
Postby AceSniper » Wed Jan 31, 2007 2:32 am
slighty_sykotic wrote:But yes, it will run. With loom, ecu and map sensor. But you will need the blacktop throttle bodies or will need to modify your ones to get a stable map signal from all 4 throttles.
--Sykotic
no you wont you can get a steady vacume from all 4 on the gearbox end of the engine. blacktop ecu is ore agresive map than a silvertop
AceSniper
Postby slighty_sykotic » Wed Jan 31, 2007 12:41 pm
You sure about that? Andre from speedtech and Brent from speedworks both reckon that its not stable enough there.
And thats exactly why the blacktop have that mini manifold to collect the signal.
--Sykotic
slighty_sykotic
Postby AceSniper » Wed Jan 31, 2007 7:07 pm
silvertops DO have a collector its just done in a diffrent fassion....
there is a steady vacume there, been there done that...
another fact all 20v's run there FPR off one throttle body that = bad signal
AceSniper
Postby AceSniper » Wed Jan 31, 2007 7:23 pm
I have used this line to run a vacume guage, better vacume to fpr, have a mate using it for a link map sensor and BOV vacume.
blacktop loom in a ae101 engine bay is almost all plug in items, its only the dash claster you need to worry about wiring
AceSniper
Postby antonio » Wed Jan 31, 2007 10:20 pm
thanks bro so it will go straight in no worrys or mods
AK
antonio
Postby AceSniper » Wed Jan 31, 2007 11:16 pm
you will need to wire the ecu to body loom part by hand
AceSniper
Postby nite b » Fri Feb 02, 2007 6:45 pm
Wired a couple of these ecu/looms over silvertop engines and kicks ass over AFM setup. Will need to rewire to car as Acesniper says tho, but worth it. Also sounds real trick with trumpets.
Have fun!
Convert Ltd
The conversion specialist
nite b
Postby vvega » Fri Feb 02, 2007 8:27 pm
slighty_sykotic wrote:You sure about that? Andre from speedtech and Brent from speedworks both reckon that its not stable enough there.
--Sykotic
been there done this
and yes you gain power
and yes it drives well and yes it friggin eazy
and a acumulator fixes teh map signal problem
vvega
