Damaged Engine Mount?
Postby astrae » Fri Jan 26, 2007 1:47 pm
Hi Guys,
I'm getting a bit of knocking in my front right suspension. I normally get it at low speed, going over speed bumps etc..
And also when the engine is at the point of stalling when moving around slowly without enough throttle. (manual)
The car is a Ae111 BZ-g Levin.
I've had a good look at the struts and subframe, everything seems to be nice and tight, I don't really know what to look for with a damaged bush.
I've taken a couple of photos of the engine mount. It looks a bit dodgy to me.
On the outside of the mount there seems to be this bit of rubber that I can move a little by hand. Does this look right? (circled in red)
And on the other side it almost looks like the mount is being pulled out.. Hard to explain and take photos of..
Any thoughts? What else should I look for?
astrae
Postby Quint » Fri Jan 26, 2007 1:57 pm
Look for sway bar bushings, they can rattle when they get worn, becareful tho, when u jack it up weight will pull it down and tighten it up.
could also be ur suspension bushings if it kinda squecks as well as rattle.
Quint
Postby Punter » Fri Jan 26, 2007 2:37 pm
Mount could be stuffed, but by the look of it the knocking noises are coming from elsewhere.
Wheel nuts tight ? (Stupid but it happens)
Nut on the top of the strut? I've had that before
Or as said sway bar end links or bushes.
I have that idle problem as well seems random. I think its th ISCV but I can't be stuffed trying to fix that, it's under the TB's.
Punter
Postby Toymota » Wed Jan 31, 2007 11:44 am
I had a knocking sound coming from the front right on my ST185.
Checked the nut on top of the strut and it was loose and after tightening it the sound is gone.
Cheers Punter for the suggestion!
Toymota
Postby astrae » Wed Jan 31, 2007 1:50 pm
Toymota wrote:I had a knocking sound coming from the front right on my ST185.
Mine are all good. Its funny, since I've had the car up on stands to check everything out, the noise has basically gone...
astrae
Postby Cakky » Wed Jan 31, 2007 10:27 pm
you haven't put new wheels on lately have you
when i did on my ae92 i got a weird as knocking noise, the shank and washer nut i was using were not sitting flush against the hub, using another washeer fixed this
just a suggestion
Cakky
Postby astrae » Thu Feb 01, 2007 10:34 am
Cakky wrote:you haven't put new wheels on lately have you
just a suggestion
No havent got new wheels. Got new tyres about 2000km ago.
astrae
Postby ollieboy » Thu Feb 01, 2007 10:34 pm
Punter wrote: I think its th ISCV but I can't be stuffed trying to fix that, it's under the TB's.
I think the check engine light would show up if it was ICV?
ollieboy
Postby Mr Revhead » Fri Feb 02, 2007 7:47 pm
no, wont show the check light
Postby ollieboy » Fri Feb 02, 2007 10:23 pm
Ok, just thought it might because it did on my mums Yaris.
ollieboy
