Can i just plug the 4afe ecu out and put the 4age 20v ecu on
Postby antonio » Fri Feb 02, 2007 10:13 pm
Could anyone tell me if i can connect the 4age 20v ecu on the 4afe loom
because im putting the silvertop engine into my ae111 levin and im wondering if i can keep the 4afe map sensor wiring loom setup, can some1 tell me if Icould do it with a few mods or?????
AK
antonio
Postby DriftSpecStarlet » Fri Feb 02, 2007 10:41 pm
Doesnt sound logical at all, 16v and a 20v ecu? ge and fe?
Toyota Celica ST185
Big f'n front mount,
Bodykit (actually looks decent)
Lowerd on blue Springs
T3/T4 Turbo
BOV
All the gadgets!
DriftSpecStarlet
Location: Gisborne, New Zealand, Earth, Universe, Milky Way.
Postby Cakky » Sat Feb 03, 2007 12:56 am
why are you putting a silvertop in??
are you going to turbo it??
my friend changed his ae111 4afe to 4age blacktop, i don't think the loom required much modification... silvertop could be much different though...
Cakky
Postby big_boy » Sat Feb 03, 2007 8:35 am
it would be easyer just to plug it all in & know its going to go there not much work involved if you conect it all up while the motor is out any way & then its just feed it thro a grommet in to the ECU & plug it up & maby change dash plugs
for sale EE90
big_boy
Postby 20v_rollaboy » Sat Feb 03, 2007 9:18 am
No, just use the silvertop loom. It isnt that hard to re-wire dash plugs for 4age ecu.
20v_rollaboy
Postby KinLoud » Mon Feb 05, 2007 4:32 pm
BIG PIECE OF FREE ADVICE!
If you can find a blacktop 20v motor and loom it will just plug in and work - no shagging around! AE111 blacktop replacing ae111 4afe real easy. (make sure it matches you transmission i.e. auto to auto or manual to manual)
If it was AE101 20v replacing AE101 4afe pretty easy, I've done it just one jumper wire needed to get the fuel pump working correctly with the AFM.
But - AE101 20v into AE111 4afe - don't think anyone here has done it yet. You will have to shag around with the wiring. Not impossible but expensive if you have to get someone to do it for you!
Ken
Ham
021 408 863
