sergei wrote:It is misconception that ECU feeds directly from speedo sensor on gearbox.
Actually what happens sensor feeds signal to dash and dash converts it to square wave. The SPD signal from dash should be fine. No SPD signal causes lower rev. limiter (and nothing more).
MR220Vblacktop wrote:This had be disscussed in a previous thread but no-one seems to have an answer.
Lee
7rib wrote:TPS has got a 5v feed in /a siganal volts back to ecu /and earth.Disconnect plug at tps and check for 5v feed with volt meter
7rib wrote: the earth wire is black and white most of the time but double check .
7rib wrote:.Plug tps back in and check out volts back to ecu it be .5 volts closed and around 4.5 fully open when opening do slowly and watch voltmeter reading should be a steady climb up in volts if you see a jump in volts like 1.5v to 2.2 then there is and fault in tps and this can cause a flat spot also what fault codes have you got.
7rib wrote:So you are saying that if you unplug sensor and use voltmeter there is no voltage at any of the wires.
