custom i/c cores
custom i/c cores
Postby NOLAW » Sun Feb 11, 2007 2:37 pm
where can i get these done but at a decent price?
NOLAW
Postby evil_si » Tue Feb 13, 2007 2:19 pm
easily done but,
the biggest issue i had with making these was the cost of the core it self,
the last core i purchased cost me $578, for 550x320x75, then i spent over a day fabricating the tanks.
evil_si
Postby NOLAW » Tue Feb 13, 2007 4:45 pm
shit lol where bouts did you get the core? are there any cheaper places or is that around what they all charge? im needing a 450x300x50-54 (not sure yet)
iv got someone sussed to do my end tanks for nothing so yeah
NOLAW
Postby evil_si » Tue Feb 13, 2007 5:51 pm
granted that was a year or so ago, but yea new cores arnt cheap, it is cheaper to buy a cheap cooler with the core size ur after off trademe and cut the tanks off and start again,
evil_si
Postby Zak » Tue Feb 13, 2007 9:49 pm
evil_si: Would you know how much it would cost to have a intercooler refined? Just an aporx price would be great thanks :)
Zak
Postby bluemaumau » Tue Feb 13, 2007 10:39 pm
isnt the best thing to grab truck intercoolers and cut them down, as theyre generally mint
just a fairy tale probley :lol:
Postby evil_si » Wed Feb 14, 2007 5:29 pm
late model truck cores are good, but the width cant be changed, well it can but its not worth the painstaking hassle.
the height is easily changed.
recoring an intercooler isnt hard depending on the type, the cost comes down core availability thena couple of hours for the fabrication time
evil_si
Postby rage » Thu Feb 15, 2007 8:44 am
what are the benefits of using a custom core? are they better quality than the coolers you'd find on trademe etc?
rage
Postby big_boy » Thu Feb 15, 2007 9:13 am
its alot more a better size thing than a quility thing they can be made exactly to size
but yes quility is normaly better as well
for sale EE90
big_boy
Postby rage » Thu Feb 15, 2007 9:26 am
does anyone have any info about the size of intercooler to support various power levels ? or some sort of guide to sizing an intercooler appropriately for a specific application?
rage
Postby big_boy » Thu Feb 15, 2007 9:41 am
you caould always go with the RICE boys idears the bigger the inter cooler the faster it goes :lol: :roll: :roll:
there a toyota in dunedin like that 1300cc 12psi & 850*500*85mm inter cooler it um yeah
my NA corolla bets it :P
for sale EE90
big_boy
Postby rage » Thu Feb 15, 2007 9:46 am
Thats the type of thing im trying to get away from. Maximum efficiency, because once you pass the size of intercooler which suits your power level or engine setup, youre just creating more restriction and getting less response. I dont care about bling or anything anyway, the intercoolers going to be designed for max flow and hidden behind the bumper
rage
Postby big_boy » Thu Feb 15, 2007 9:53 am
altho i cant help you with sizes i will say you have the right idear in mind
each to there own but i beleave that a fast car done right well out douse a slow car done with bling i dont see the point why any one wants to spend all that money on a car just to comprise profamce over looks
my 2c
what is you car motor/boost PSI & power aim also how much have you done the the internals im sure some 1 can help you witc sizes
for sale EE90
big_boy
Postby rage » Thu Feb 15, 2007 2:58 pm
the setup im thinking of is
1800cc
10:1 comp or 10.5:1
td05 big 16g
the turbo can support 380hp so i suppose thats the power figure im aiming for
rage
Postby NOLAW » Thu Feb 15, 2007 4:11 pm
yeah thats the whole point im looking into custom core so i can hide it and not have to cut up my grill, bumper, valence etc
NOLAW
Postby peas » Fri Feb 16, 2007 2:30 pm
rage wrote:the setup im thinking of is
1800cc
10:1 comp or 10.5:1
td05 big 16g
Correct me if I'm mistaken but thats some high compression for a turbo setup isn't it? Well unless you have your gate set to dump at 5~6psi... Though your power figure makes me think that you are planning at least 4 times that.
'97 Caldina GT (ST215G)
peas
Postby rage » Fri Feb 16, 2007 2:39 pm
1800cc
10:1 comp or 10.5:1
td05 big 16g
yes its a relatively high compression figure. 10:1 is definitly possible. 10.5 is getting a bit high. I plan to run around 1 bar on pump gas, aiming to use 95octane if I can get away with it. Because of this high compression, detonation is going to be a problem which is why i need a very good intercooler to keep the charge temps down.
rage
Postby matt dunn » Fri Feb 16, 2007 7:30 pm
I an doing an 1800 turbo engine also,
Would like to get it close up to 10:1, and it needs to make at least 380hp
or the whole thing is not worthwhile.
Looking at the high comp ratio as my race class has an 18psi boost limit.
Matt
Postby rage » Fri Feb 16, 2007 7:55 pm
use your cams to change the dynamic compression ratio. the standard ratio is just your max comp value u can attain.
so if you are clued up enough, run you car as high as you dare, then use your cams and the intake valve close degree to alter your dynamic compression ratio to one that you can sufficienly fuel and run without detonation.
rage
