ok more than i thought. thanksmr pad wrote:1. Warm engine up
2. Take off sump cover (if there is one)
3. Remove dip stick and oil filler cap
4. Remove sump bolt (make sure its not the auto trans bolt)
5. Let oil drain
6. Replace the $&#$% oil filter, watch out for letting it leak onto things (like starter motors in fto's... doh)
7. Replace oil filter making sure there is a thin layer of new oil on the filter gasket. Filter should make contact, then another 3/4 turn or till its tightish
8. Replace sump bolt if oil has finished draining.
9. Fill engine with oil through filler cap, pour around 3 ltrs in and then keep checking on the dip stick making sure you dont overfill.
10. Start engine for 10seconds
11. Wait 10mins and check oil level and check for leaks
12. Piss off I can't believe I just wrote that sh*t, must be in a good mood.
5. Let oil drain
5. Let oil drain
agressor wrote:
the engine oil is low. do i have to empty out all the oil and then pour in new oil?
or just pour the oil in with whats left of the oil
mr pad wrote:6. Replace the $&#$% oil filter, watch out for letting it leak onto things (like starter motors in fto's... doh)
agressor wrote:who are youquicklvn wrote:Lol![]()
I'll cum over and do it with you in the weekend if you want.
Give me a text
5. Let oil drain
scope wrote:i've been told both to change oil while the car's warm and the car's cold. what one is it?
Users browsing this forum: Google [Bot] and 1 guest
