certing bonnets
certing bonnets
Postby bluemaumau » Wed Feb 14, 2007 10:57 pm
ok so ive decided to get a cert when i get my car going again, and was just wondering if anybodys been thru anything like this before.
my bonnet is a standard ae101 corolla bonnet, which i have cut a 20cm x 30cm (approx) hole into and bolted a scoop to this and bogged in the bastard in.
im guessing as most shit needs certing now this will, so does anybody know if this will pass, or do i need to trawll thru endless amounts of BS on lvvta?
im hoping
Postby Bling » Thu Feb 15, 2007 12:57 am
local KE30 (or the likes) has a plain hole cut out (at a guess 20cm x 20cm) of the bonnet where the turbo sat, so i'm sure you should be able to get yours thru without too much BS :)
it just occured to me that i'm not 100% they had it certed.... so hmmm ring a local cert person :lol:
Postby CAMB01 » Thu Feb 15, 2007 7:28 am
I think it comes under external projections.
My bonnet scoop was under external projections on my cert plate
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby bluemaumau » Thu Feb 15, 2007 9:36 am
cam did you just cut a hole in the bonnet of the fx and shove a scoop on?
basically what i did except i bogged mine in (bog fixes everything) :lol:
Postby Zak » Thu Feb 15, 2007 9:55 am
If the scoop is secure you'll have no problems.
Zak
Postby bluemaumau » Thu Feb 15, 2007 1:42 pm
hardener+ bog = secure
:lol:
cheers all,
my main thought was that when i cut the hole i obviously have to cut thru the crumple reinforcing thingies, (the metal underneath your bonnet that looks like a big net)
Postby B ROWDY » Thu Feb 15, 2007 2:26 pm
As long as you havnt chopped through the main supports and its secure then you are fine
B~ROWDY The Thread Whore Formerly Known As SERABABY
B ROWDY
Postby bluemaumau » Thu Feb 15, 2007 4:07 pm
what are the main supports?
Postby B ROWDY » Thu Feb 15, 2007 4:26 pm
For example in this pic you definatly cant cut the parts that form an "A" shape under the bonnet - big fat lines, but you can get away with the smaller ones on both sides if you have to, I wouldnt be too keen on hacking any part up like that, but thats just me lol
Sorry bout the size, maybe someone can photoshop the lines on the pic and make em red or something, since I dont have any thing on this pc at work lol
B ROWDY
Postby bluemaumau » Thu Feb 15, 2007 4:31 pm
ok cheers for that but corollas dont have those thicker supports!
i cut basically dead center of the bonnet as thats were the i/c sits
Postby B ROWDY » Thu Feb 15, 2007 4:33 pm
Yeah couldnt find a pic of a rolla lol, just go hardies and cross your fingers :lol:
B ROWDY
Postby Infinite » Thu Feb 15, 2007 5:39 pm
the ceritifyer in te awamutu maurice thompson motorsport told me i can cut all the supports off my bonnet because its a bolt on panel but if i put a bonnet scoop on its gota be certed lol luckily i got away with removing the a frame ;P
Lots
Infinite
Postby Bling » Thu Feb 15, 2007 5:42 pm
thats all good till some fat bastard sits on ya bonnet :lol:
Postby Infinite » Thu Feb 15, 2007 5:47 pm
u let people sit on your car?
Lots
Infinite
Postby Bling » Thu Feb 15, 2007 6:50 pm
who said anything about permission? I don't let people push trolleys into my car either :evil: but it happens.
:lol:
Postby CAMB01 » Thu Feb 15, 2007 8:54 pm
bluemaumau wrote:cam did you just cut a hole in the bonnet of the fx and shove a scoop on?
Had panelbeaters do it, they cut a hole and bolted the sccop on, as its a scoop from a AE92 GTZ, which a just bolted on. And they painted the bonnet.
CAMB01
Postby bluemaumau » Thu Feb 15, 2007 9:24 pm
yea mines a ae92 scoop also but ae101 bonnets slowly bend so i had about 2cm of clearance at the front so out came the bog
Postby CAMB01 » Thu Feb 15, 2007 9:26 pm
hahahahahahaahaha all good. Just be careful that you dont park the car with the scoop into the rain, it fills the sparkplug valley up with water and the car runs crap lol
CAMB01
