mag wheel spacing
mag wheel spacing
Postby kingcorolla » Wed May 03, 2006 9:09 pm
Hey how can i space my mags out 5mm from the hub and still retain load on the spigot?
do not need longer studs as i currently have 5mm multifit spacers on but they are dodgy and illeeegal coz the the wheels dont locate!
Bolt on adapters seem overkill since I only need 5mm clearence, is there an easier and more certifyable way i could consider thanks
1983 Carina AA63 4age
kingcorolla
Postby bluemaumau » Thu Feb 15, 2007 4:18 pm
can anyone answer this?
yep
Postby TOYROTA » Thu Feb 15, 2007 4:28 pm
i would say goto the ltsa website and look it up as there are so many different aspects to consider with spacers
Curre3nt rides-
1982 starlet kp61 4 door (in panel shop getting bare metal resto)
1980 tt132 corona wagon 3t t40 (daily doomsday machine)
TOYROTA
Postby bluemaumau » Thu Feb 15, 2007 4:34 pm
im completely new to spacers so im still getting my head around it.
i see there are two types
1. a type which come with new studs and bolts onto the existing studs
2. a type which is basically a big washer.
if i was to use (1) how the $&#$% would i bolt the original studs to it ? and still get the mag wheel flush witht the spacer!?
do i need to get custom hubs or my studs lenghtened?
Postby bluemaumau » Thu Feb 15, 2007 4:44 pm
i want 5mm btw, im thinking about just getting the washer type, ill see if it gets enuf bite
Postby Bling » Thu Feb 15, 2007 5:05 pm
I "heard" so yeah possibly BS
That you could cert spacers that had locating rings in the centres for wheels, only what I thought I saw
Postby postfach » Thu Feb 15, 2007 5:10 pm
yeah you need to get a hubcentric ring made up, should be pretty easy for an engineering place, and cheap. ideally you would want spacers that had the ring integrated, less parts = less stuff to go wrong (only bad thing about this is that you will only be able to fit wheels with the correct sized hole).
also afaik slip on spacers (the simple washer type) are illegal.
postfach
Postby TWSTD » Fri Feb 16, 2007 11:33 am
We sell a range of spacers (which TS members get a discount on of course) ranging from 3mm up to 50mm in thickness. The thinner ones (less than 15mm) are slip on spacers, and thus are not load bearing. The thicker ones come with studs installed, and these bolt in place. Some are load bearing and some are not. As stated above, you will need to check the LTSA regs and your local WOF agent perhaps depending on your use for them.
@@@ Online store NOW OPEN! @@@
Click here!
DPR | HTS | SARD | WALBRO | GARRETT | SPEC | EXEDY | MINTEX | HKS | APEXi | MAPECU | SIMOTA + more!
TWSTD
Postby RickGT » Sun Feb 18, 2007 6:23 pm
what sort of discount are we talkin? :)
MX73 GLXi Cressida 1JZ-GTE
EP91 Glanza V
RickGT
Postby TWSTD » Sun Feb 18, 2007 9:32 pm
on most spacers its 10% for TS members.
Click here!
TWSTD
