the fallen303 wrote:there is nothing wrong with the 2jzge. they still come with 230hp, which is a lot n/a! for a daily for the missus and a tow wagon on weekends, i'd take the gita. she'd probably never use the turbo, and when you're towing, the extra torque lower down and off boost of the 2j would probably suit it better. just remember the 4wd gita's only come auto, so if you're gonna tow, get a decient trans cooler, and it'll tow for miles.
flygt4 wrote:it helps when u read the thread before you post.
the 2jzge here is not in a supra chassis , its in a gita/altezza , which is significantly lighter than the lardass supra body.
the 3L has more power and torque than any other engine available on that platform, and at 1350ish kg with the 135-145-ish kw atw that the engine makes they are a pretty under rated alternative.
I for one would prefer it over the caldina GTT, and you'll probly find if you do the maths the power to weight ratios are very similar.
1 year ago when we were looking, the gita were sitting at around 25-30k, unsure of pricing now , tho i would expect to be able to find a nice one in the low 20's.
Curb vehicle weight, kg 1480
Max.power (Net), kw(PS)/rpm 220 ps (161.81 kw) / 5800 rpm
Max.torque(Net), N*m(kg*m)/rpm 30.0 kg*m (294.20 N*m) / 3800 rpm
Power density 6.73
Curb vehicle weight, kg 1440
Max.power (Net), kw(PS)/rpm 225 ps (165.49 kw) / 6000 rpm
Max.torque(Net), N*m(kg*m)/rpm 29.0 kg*m (284.39 N*m) / 4800 rpm
Power density 6.4
Curb vehicle weight, kg 1470
Max.power (Net), kw(PS)/rpm 260 ps (191.23 kw) / 6000 rpm
Max.torque(Net), N*m(kg*m)/rpm 33.0 kg*m (323.62 N*m) / 4400 rpm
Power density 5.65
Users browsing this forum: No registered users and 26 guests
