4AGE / GZE the same?
Postby Fortyone.co.nz » Tue Feb 27, 2007 2:38 pm
Just a quick question, if a cam suits a 4AGZE, will it suit a 4AGE Blacktop? Same with crank? Rods? Pistons? Ta!
Fortyone.co.nz - For Bride, EBC, KTS, JUN, Tomei, HKS, Trust, Blitz and more!
Fortyone.co.nz
Postby HELBND » Tue Feb 27, 2007 2:42 pm
cams, no. pistons, probably not. crank and rods, i see no reason why not
HELBND
Postby Silent Knight » Tue Feb 27, 2007 2:44 pm
HELBND wrote:cams, no. pistons, probably not. crank and rods, i see no reason why not
That answer is probably not the definitive one he was looking for. :lol:
Silent Knight
Postby HELBND » Tue Feb 27, 2007 2:47 pm
well it was all i could be bothered typing.
exhaust side cams would fit, but intake cams would not as theres an extra 4 valves that need taking care of and youd lose your vvt
pistons are unlikely to work as you would need an extra valve cutout to accomodate the 5th valve for each cylinder.
crank and rods afaik are inderchangeable throughout the 4age series
HELBND
Postby IH8TEC » Tue Feb 27, 2007 3:22 pm
cams will just not work, 4agze's are 16v and the blacktop 4age is 20v :roll:
pistons are slightly different becuase of the extra valve
rods, yes
Re: 4AGE / GZE the same?
Postby thaphatty » Tue Feb 27, 2007 4:30 pm
Fortyone.co.nz wrote:Just a quick question, if a cam suits a 4AGZE, will it suit a 4AGE Blacktop? Same with crank? Rods? Pistons? Ta!
cams = no 16v vs. 20v
rods = yes
crank = yes
pistons = yes but motor becomes interference
Same does not apply to anything less than small port in a 20v.
ie. bluetop cams, crank, rods and pistons wont fit (well would but would require silly, silly amounts of modification)
thaphatty
Postby lorolla24 » Tue Feb 27, 2007 7:59 pm
You can use 4AGZE pistons with silvertop head. Many use them for turbo application. I would guess they work with a black top head.
Just don't brake your cam belt, then you will have prob's.
lorolla24
