pyro_sniper2002 wrote:Well then hes not doing a very good job at a wof. They should check the pattern, i failed on the sprinter on that before.
Leon wrote:the headlights on a LHD car will indeed have a different light spread than those on a RHD car.
postfach wrote:hold on, aren't there HID kits that don't actually have the headlight lens or reflector, and are just the bulbs and ballast, no actual headlight housing?
if you get one of those, you wont have a problem with the light shining on the wrong side of the road....
big_boy wrote:just out of question what is the advantages/disadvantages of it
Users browsing this forum: Bing [Bot] and 1 guest
