ae92 cvs
ae92 cvs
Postby slighty_sykotic » Tue Feb 27, 2007 11:33 am
Hi,
Anyone know if ae92's normally have a "tripod" type cv, or a ball race type outer cv?.
Want to tow a car with no gearbox, and axles are hanging down, would like to break the outer cv in half (need it to be tripod type), so that I can tow it without axles hanging everywhere.
-Sykotic
slighty_sykotic
Postby IH8TEC » Tue Feb 27, 2007 2:19 pm
my ae92 gtz has ball and race outer
Postby slighty_sykotic » Tue Feb 27, 2007 2:26 pm
Bugger....
Anyone got a set of cvs around the palmy area I can borrow?
(its too difficult to get tools out to where this car is, remove shafts, remove cvs and put back).
And I can't get a trailer there.
slighty_sykotic
Postby Bling » Tue Feb 27, 2007 2:32 pm
do you guys not get these up north?
:lol: there must be some way tho to tie them up? or did I read something wrong
Postby slighty_sykotic » Tue Feb 27, 2007 2:47 pm
yeah.... but i have to tow it a fairly decant way... If worse comes to it, yeah I will tie them up and tow it to somewhere I can get a trailer or tools to remove the cvs.
--Sykotic
slighty_sykotic
Postby big_boy » Tue Feb 27, 2007 2:49 pm
just undo the 32mm bolt & knock them out with a hammer
if it dousent work get a bigger hammer
for sale EE90
big_boy
Postby slighty_sykotic » Tue Feb 27, 2007 3:38 pm
You can't tow it without a cv in place. The cv holds the wheel bearing/hub together.
slighty_sykotic
Postby big_boy » Tue Feb 27, 2007 3:54 pm
never seen that before but ok
for sale EE90
big_boy
Postby Ae92typeX » Tue Feb 27, 2007 6:59 pm
slighty_sykotic wrote:You can't tow it without a cv in place. The cv holds the wheel bearing/hub together.
big_boy wrote:never seen that before but ok
I cant think of a cv drive application where this is not how it works.
yeah, if no luck, go with the cable tie thing, but get the big jobbies, use several a side & use grease
Ae92typeX
Postby big_boy » Tue Feb 27, 2007 9:52 pm
iv towed 2* EE90`s like that & never had a problam
for sale EE90
big_boy
Postby slighty_sykotic » Tue Feb 27, 2007 10:03 pm
It doesnt fall apart straight away, but it will $&#$% the bearing, and if its all loose (ie, been apart before), its going to fall to bits.
slighty_sykotic
Postby bluemaumau » Tue Feb 27, 2007 10:10 pm
my gtz shafts had the ball type on both ends
Postby bluemaumau » Tue Feb 27, 2007 10:11 pm
i think all 4ages have the tri type, my ae101 wreck (silvertop) had tri type
Postby Caveman » Tue Feb 27, 2007 10:12 pm
If its manual non supercharger (c52) it'll be the std tripod outter cvs with the single circlip holding them on. Im not sure about auto thou...
You can tie the driver side up on the cross member, and hang something down from the engine mount to hold the passenger side up, I would do this to stop the spline getting all chipped and mashed.
Is it supercharger or na? I know supercharger have the ball bearing/race arrangment on the outters as ih8tec said.
lol at removing the stub axle thats just looking for trouble
AW11 Track Toy
Formerly known as 1998
Caveman
