Norty wrote:Well well well. Knock is gone, and it was the cambelt, bit loose and we tighten it up and the knock is gone totally. my mate said even tho we put a new tensioner on it has come loose, and he was told by the guy that trained him up that these engines can do this due to their design i am sure someone will disagree but hey my knock is GONE YAYAYAYAYYAYA
SO CHEERS YAYAYAYYAYAYAYA
Now for the new turbo mUahahahhahahahaha
Norty wrote:Well knock has come back. Not impressed. Rang Repco Turns out there is another cambelt for a 3sgte (part T777) that has 1 less tooth.
Going to get this cambelt and give it a try. Just keeping this post updated for future toyspeeders that may encounter the same issue.
rollaholic wrote:personally i always buy my cambelts from toyota, its really true what they say about genuine parts - not to mention, for the price they charge (extremely reasonable) i dont know why you wouldnt.
Ae92typeX wrote:Assuming its the correct one, ive never had issues with gates belts. did 100k on one and when went to replace had no obvious wear.
how much slack are you getting? (measured either belt deflection or tension on belt you can share?)
Norty wrote:rollaholic wrote:personally i always buy my cambelts from toyota, its really true what they say about genuine parts - not to mention, for the price they charge (extremely reasonable) i dont know why you wouldnt.
how much is a cambelt from them? my gates was $55 besides gates are really good belts, they have alot of history. never had an issue with them before i run one on my GTZ.
Norty wrote:Ae92typeX wrote:Assuming its the correct one, ive never had issues with gates belts. did 100k on one and when went to replace had no obvious wear.
Well lets put it this way, the tensioner has its pee pee fully out and the slack on the belt would be in my non technical terms about 5mm slack, this weekend when we take off the belt i can take a video of the slack and post on youtube.
We have tested the tensioner, using the tests in the celica BGB.
unless their is another tensioner for this engine or idler pulley then i can only look at this other cambelt with one less tooth.
Norty wrote:Clearance between tensioner body and idler pulley is 2.5mm
The head has been shaved 30-40 thou and it has a thinner metal head gasket on it. about 1/2 a mil
fivebob wrote:Norty wrote:Clearance between tensioner body and idler pulley is 2.5mm
That's well outside spec, it should be 1.8-2.2mm.The head has been shaved 30-40 thou and it has a thinner metal head gasket on it. about 1/2 a mil
So you shaved 1mm off the head and then lowered it another 0.5mm, that's adding 3mm more slack to the belt. No wonder it's loose. I would suggest that the most sensible way to fix this is to use a thicker headgasket 1.5-2mm should solve the problem.
Norty wrote:Can i get a metal head gasket that is 1.5-2mm
its a big mission, mod road is looking good around about now, what about a smaller idle pulley? how small would i need from standard to fit a belt with 1 less tooth, i couldn't go bigger pulley as not enough room but i could go smaller yeah.
