ae92 gtz fuel use problem
Postby devius » Thu Mar 08, 2007 6:00 pm
hey people
my ae92 gtz has started using more than the normal amount of petrol
the spark plugs are pretty rooted so im getting more but its not just that (i think) when i start it from cold the revs go up and drop down a few times then settles, the same happens when its warm except its worse and it does not settle until it cools down.
could it be the A.F.M?
any idea's?
devius
Postby IH8TEC » Thu Mar 08, 2007 7:16 pm
has anyone tinkered with the afm at all?
Postby devius » Thu Mar 08, 2007 7:30 pm
not that i know of man, why what ya thinking?
devius
Postby IH8TEC » Thu Mar 08, 2007 7:49 pm
there is a mixture screw on the afm, should be easy to see, but if thats been tinkered with it can stuff the idle etc. (DO NOT PLAY WITH IT) unless you measure exactly where it is FIRST. trust me from personal experience lol.
also yeah change the plugs.
how many kms you getting to a tank???
Postby devius » Thu Mar 08, 2007 8:36 pm
not sure of k's but i had 3/4 of a tank and that was gone in two and a bit days, that much would nornally last me a week, oh real, should i get a mechanic to look at the mixture screw?
devius
Postby IH8TEC » Thu Mar 08, 2007 9:03 pm
umm maybe see what other things people suggest before taking it to a mechanic, i can't think off the top of my head, all this time away from my car i forget stuff lol
Postby Lloyd » Thu Mar 08, 2007 9:06 pm
Change plugs and check fault codes first. If plugs dont fix it then go from there
Postby devius » Fri Mar 09, 2007 6:00 pm
sweet as, got some plugs today gonna chuck them in soon, how do i check for fault codes?
devius
Postby bluemaumau » Fri Mar 09, 2007 6:55 pm
bridge terminals e1 and te1 i think count flashes of engine check light
Postby devius » Fri Mar 09, 2007 7:06 pm
and where are these terminals? lol
devius
Postby bluemaumau » Fri Mar 09, 2007 7:09 pm
little black box about the size of a matchbox, i think there on the strut tower(passenger side)
remove the lid and bridge the correct terminals
Postby devius » Fri Mar 09, 2007 7:12 pm
ok found that but the box is filled with some sort of shit
devius
Postby Mr Revhead » Fri Mar 09, 2007 7:29 pm
DO NOT TOUCH THE SCREW.
pretend its not there
that gunk is anti corrosion, ignore it.
Postby devius » Fri Mar 09, 2007 7:42 pm
lol thanks rev head, i am not gonna touch the screw lol
devius
Postby devius » Fri Mar 09, 2007 7:43 pm
ok under the box it has e1 and t are they the ones to use?
devius
Postby bluemaumau » Fri Mar 09, 2007 9:28 pm
yea im 99% sure those are the ones
Postby Crampy » Fri Mar 09, 2007 11:03 pm
Could be your oxy sensor. My one was stuffed in my S/C AW11 and it would use a bit more gas. It would occasionally throw a check engine light too. Got it replaced and it was sweet.
Crampy
Postby devius » Sat Mar 10, 2007 10:30 am
ok new spark plugs are in, rungs alot better but no better on idle when warm, ok so i plug e1 into t and see how many times the engine light flashes???? once i have the number of times it flashes where do i find out what it means???
devius
Postby Zak » Sat Mar 10, 2007 10:42 am
Just post it up, or search for toyota ecu codes on google and have a look :)
Zak
Postby bluemaumau » Sat Mar 10, 2007 12:23 pm
viewtopic.php?t=35814
count the falshes then there should be a short pause and then more flashes then a long pause the a repeat or another code
i.e flash flash flash flash flash short pause flash long pause repeat - error code 51
