GZ20 Stock Diff into GX81?
Postby thegreatestben » Fri Mar 09, 2007 2:02 pm
Is a Stock lsd diff out of a GZ20 Soarer bolt into GX81 with IRS?
I've bought Loonies GX and I know of someone with a Soarer stock lsd.
If it does fit what would you price the lsd being worth?
thegreatestben
Postby thegreatestben » Fri Mar 09, 2007 2:03 pm
Also are GA70 Supra brakes an easy upgrade for the Chaser?
thegreatestben
Postby postfach » Fri Mar 09, 2007 3:42 pm
yes the diff fits, GA70 brakes are the smallest of the lot, i had them on my MZ20, 280mm front discs, ffs, too small, get the big ma70 ones or buy 300mm discs from BNT or somewhere and fit JZA70 calipers like i did (if you can find them)
but to answer your question yes the brakes will bolt on, just check the sizes to make sure you aren't swapping something identical.
and the going rate for G series LSD seems to be around $500.
postfach
Postby thegreatestben » Fri Mar 09, 2007 3:56 pm
Ah excellent, I shall try to score it.
Is it worth the money? Are they a good unit, any advice or experiences?
I'll have a measure up of the brakes too.
thegreatestben
Postby postfach » Fri Mar 09, 2007 4:00 pm
i never used a clutch pack lsd because i bought a torsen for mine, and the car came with an open, but as long as its still nice and tight it should be fine for a few ponies, loonie should have some idea since i think hes had them in his cars. if its in good nick, then yes i'd say its worth the money, when i had the open diff it was pretty useless, i got one wheel of fury just driving gently around corners and under moderate acceleration, it was especially terrible in the wet.
postfach
Postby postfach » Fri Mar 09, 2007 4:03 pm
let me know how it goes with the brakes.
postfach
Postby thegreatestben » Fri Mar 09, 2007 4:03 pm
Well i'm repowering with the mighty gen 3 1ggte :twisted:
thegreatestben
Postby blackmk3 » Sat Mar 10, 2007 10:27 am
Facelift Ma70s also had 300mm rotors not just the jza70's
I have a standard clutch pack LSD in my supra, came out of a 87,000km car and it still hooks up third gear with both wheels still spinning, so unless ur a drifter with a good condition stocker id say you will keep happy
Mk3 MA70 Supra
blackmk3
Postby blackmk3 » Sat Mar 10, 2007 10:29 am
sorry just reread :oops:
I have a standard clutch pack LSD in my supra, came out of a 87,000km car and it still hooks up third gear with both wheels still spinning, so unless ur a drifter, A good condition stocker i would say you will keep happy
Mk3 MA70 Supra
blackmk3
Postby thegreatestben » Sat Mar 10, 2007 11:08 am
Cool, any advice on pulling the diff out? Will i just need a decent socket set etc..?
thegreatestben
Postby postfach » Sat Mar 10, 2007 5:34 pm
yeah socket set and some spanners, careful when you pull it out not to let it fall on you, kinda heavy :P
postfach
Postby thegreatestben » Sat Mar 10, 2007 8:15 pm
Turns out it was open diff, but i ended up buying the whole car for $150 bucks, has a complete 1ggte in it too but turbos have gone pop.
thegreatestben
Postby big_boy » Sat Mar 10, 2007 8:18 pm
what ratio is it i may by the head if its cheep & the right ratio
for sale EE90
big_boy
Postby thegreatestben » Sat Mar 10, 2007 8:40 pm
dunno havent got the car at my disposal right now but yeah how cheap is cheap?
thegreatestben
Postby big_boy » Sat Mar 10, 2007 8:43 pm
if its what i want il give you what you payed for the hole car shipped to dunedin
for sale EE90
big_boy
Postby thegreatestben » Sat Mar 10, 2007 9:00 pm
Yeah ok sounds fine with me. what numbers should the build plate read?
thegreatestben
Postby big_boy » Sat Mar 10, 2007 9:04 pm
thats the problam i dont have a clue i just need a 4.2-4.4:1 ratio in a DX corolla witch is running a F series 3.7:1 out of a XX
for sale EE90
big_boy
Postby thegreatestben » Sat Mar 10, 2007 9:29 pm
Ok just double checking will it fit into a live axle? cos this is IRS.
The third digit in the code needs to be 08 or 09 to be the diff ratio your after.
Will check it soon as I see the car.
thegreatestben
Postby big_boy » Sat Mar 10, 2007 9:32 pm
this DX has been changed to IRS with a full sub fram out of a XX
for sale EE90
big_boy
Postby thegreatestben » Sat Mar 10, 2007 9:37 pm
Ah i've seen pics of mk.1 xx's changed over, thats pretty cool.
Anyway the diff is yours if its what you want, i'll pm you when i have confirmation.
thegreatestben
