Engine on engine stand?
Postby Chickenman » Sat Mar 17, 2007 6:04 pm
I need some bolts to chuck my Blacktop on my engine stand, basically need to know where to buy them or if anyone has some suitable ones sitting around somewhere.
Chur,
Toby.
Baby Jesus
Chickenman
I Am The Walrus!
Postby Dell'Orto » Sat Mar 17, 2007 6:06 pm
Engineering shop will be the place to go, I got some from Bay Engineering here for about $2 each.
Postby RedMist » Sat Mar 17, 2007 6:12 pm
I bought my set from Blacks. Hilton Parker will also be able to supply them.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby Chickenman » Sat Mar 17, 2007 8:19 pm
Thanks guys.
Sooo... does anyone have the thread number etc for what I'm after? I haven't got a reference bolt to take with me. :oops:
Baby Jesus
Chickenman
I Am The Walrus!
Postby Lloyd » Sun Mar 18, 2007 8:37 am
Just use the bellhousing bolts
Postby Chickenman » Sun Mar 18, 2007 10:17 am
Don't have them, hence the question :)
Engine was given to me minus gearbox etc, will call a couple of places in the week.
Baby Jesus
Chickenman
I Am The Walrus!
Postby KinLoud » Sun Mar 18, 2007 12:13 pm
Bellhousing bolts are usually too short to use on an engine stand.
If you have a huge collection of bolts off random toyotas (like I do) then you might find some suspension bolts that are long enough and the correct thread/diameter.
Try to find a bolt that will thread into the holes in the block, work out how long they need to be and take the bolt and the measurements to a fastener shop.
Be aware that if the bolt is a bit too long and you do it up tight into the block you could crack the block when the bolt bottoms out.
Get 20 or so washers as well as insurance against this, if you need to.
Bolts plus washers might cost you $5 to $10.
Ken
Ham
021 408 863
Postby Mr Revhead » Sun Mar 18, 2007 1:16 pm
for the blacktop they should be 10X1.25mm
Postby TRD_ZERO » Sun Mar 18, 2007 3:40 pm
$2 each 8O i Payed $7 each for them from the bolt shop i got ripped :evil:
TRD_ZERO
Postby Malcolm » Sun Mar 18, 2007 7:47 pm
i used engine mount bolts, the large ones that run through the centre, they're the right size for 3sgtes, pretty sure the A series are the same. Were a tiny bit long on a couple so I put a slightly larger nut under them to act like washers :D
Postby Dell'Orto » Sun Mar 18, 2007 8:56 pm
TRD_ZERO wrote:$2 each 8O i Payed $7 each for them from the bolt shop i got ripped :evil:
Its good to be in the trade ;)
Postby pc » Mon Mar 19, 2007 2:43 pm
Pick-a-Part
show them a handful of bolts and pay $1
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby Chickenman » Wed Apr 11, 2007 10:34 am
Mr Revhead wrote:for the blacktop they should be 10X1.25mm
Damn you Wazza :(
Anyway, we've decided that if you want to mount a Blacktop on an engine stand you need 12 x 1.25.
That's $10 less education Mitchell will get, you bastard :o
Baby Jesus
Chickenman
I Am The Walrus!
Postby Mr Revhead » Wed Apr 11, 2007 10:38 am
hahaha i said SHOULD be :P
Postby fangsport » Wed Apr 11, 2007 5:14 pm
Mr Revhead wrote:hahaha i said SHOULD be :P
on what engine? never seen them on a Toyota other than maybe the 1nz? yaris engine.
fangsport
Postby Mr Revhead » Wed Apr 11, 2007 5:16 pm
going by memory and i was wrong, yes even the best fcuk up! :oops:
Postby fangsport » Wed Apr 11, 2007 5:22 pm
Mr Revhead wrote:going by memory and i was wrong, yes even the best fcuk up! :oops:
and moreso the average ones!! you must have spent too much spare time working on Mason's Urabus to come up with that sizing.
fangsport
Postby Mr Revhead » Wed Apr 11, 2007 5:34 pm
:lol: well.... seeing as i service the rear........ 8O :oops:
Postby fangsport » Wed Apr 11, 2007 8:03 pm
Mr Revhead wrote::lol: well.... seeing as i service the rear........ 8O :oops:
of what...............goats???
fangsport
Postby Mr Revhead » Wed Apr 11, 2007 8:08 pm
:lol: sadly no, even worse, rear suspension of a WRX :?
but thats off topic....
on topic.... whos knows sizes of 4k bellhousing bolts??
