gasman wrote:is it worth while getting arp head studs? and how much do these usually go for?
matt dunn wrote:gasman wrote:is it worth while getting arp head studs? and how much do these usually go for?
if your not planning on pulling it apart again just use brand new toyota one's,
just make sure that you only use them on the final assembly as once you do them up they may stretch.
IH8TEC wrote:matt dunn wrote:gasman wrote:is it worth while getting arp head studs? and how much do these usually go for?
i've re-used my old ones atmbut i have arp headstuds to put on my car, as i plane to pull the head off once a year maybe or after alot of competition to inspect stuff.
edit* as it's a 20v you'll need to buy two 16v kits as they dont make a kit for the 20v still. that i know of anyway, as you will need them all the same length
