options for stretched thread on driveshaft? SORTED
Postby flygt4 » Mon Mar 26, 2007 6:14 pm
it seems the thread on one of my driveshafts for the hub nut is stretched.
the thread isnt obviously damaged, but i have shown it to a fastener supplier and the thread starts off small and is noticably wider at the end when compared with a thread matching tool.
2 of the same 19mm nut that came off the shafts, now only thread half on and then lock up. a 20mm is too baggy, and the closest imperial nut doesnt work either.
anyone know any options for repairing the thread? preferably that retain the original strength. maybe sum1 on here has an engineering background or knows sumthing helpful.
flygt4
Postby sergei » Mon Mar 26, 2007 6:21 pm
Just replace the outer CV, it is the safest way. If shaft is streched it is not as strong anyway (I just can't imagine what sort of force required to streth 19mm steel shaft)...
Postby flygt4 » Mon Mar 26, 2007 6:25 pm
yeah id hate to think of the forces involved.
i seem to remember it came off quite difficult, could probly force the 19mm back on with one end in the gearbox and a huge strongarm :wink:
but then its damaged anyway and is probly a bit weaker than before.
flygt4
Postby Crucible » Mon Mar 26, 2007 6:26 pm
its quite common to flare the end slightley when tapping the joint out with a hammer, were the joints tight in the hub?
the thread probley isnt stretched its probley squashed from whacking it.
sometimes the thread looks mint but can actually be flared enough so you cant get it started, you can just take it down with a die grinder and then tidy it up with a thread file, Ive done sh*t loads like this and never had a problem.
for the few that have been quite bad, Ive just tacked the nut to the joint with the mig for extra precaution
if you get stuck bring it into work and ill have a look for you.
Crucible
Real Life Mechanic
Postby flygt4 » Mon Mar 26, 2007 6:36 pm
cool, already cleaned it with a wire brush and it only improved it by about 1/8 of a turn. bloody things are being a pain in the ass :lol:
don't spose you have any of the larger e series hub nuts lying round ur work either? they are about a 21 i think. my new driveshaft has the larger thread whereas my old ones both had the smaller thread, so im short one nut :lol: i tihnk they are fairly generic as i grabbed a couple from the garage down the road that both fit, but the one they gave me were both damaged haha.
flygt4
Postby Crucible » Mon Mar 26, 2007 6:44 pm
yeah I think Ive got a few lying around, pop it in next time your in town and ill see if I can find something that will do the job...
Crucible
Real Life Mechanic
Postby thaphatty » Mon Mar 26, 2007 6:52 pm
dont want to bodge it up? dont want to flick a die over it with some lock tight?
do you not want to do that? :D
thaphatty
Postby fangsport » Mon Mar 26, 2007 9:05 pm
don't bodger it!!
have seen ST190 Corona axles that streched to the point of parting company. car owner was curious as to what the rattle in the front hub was. after studying it for a bit, i realised it had been 90% parted for a long time as it was quite rusty.
god knows what could have happened if the bearing had collapsed.
fangsport
Postby flygt4 » Mon Mar 26, 2007 9:05 pm
I kinda like the hub staying on thanks :wink: especially considering the forces likely to be applied to it :lol:
i already has a wheel come off once, while it was interesting , im not rushing to repeat the experience.
flygt4
Postby thaphatty » Mon Mar 26, 2007 11:46 pm
she'll be right, take one arc welder, a swapper of bushmans and a pack of welding rods..
thaphatty
Postby big_boy » Tue Mar 27, 2007 12:07 am
thaphatty wrote:she'll be right, take one arc welder, a swapper of bushmans and a pack of welding rods..
who needs a welder when you have a 12V battrey in the car just a set of jumper cables is needed
for sale EE90
big_boy
Postby flygt4 » Tue Mar 27, 2007 5:47 pm
problem solved. :D
True-No-Turbo managed to get the thread to take a nut again , and i also managed to source another nut for my other new shaft while i was there.
hopefully its the last annoyance to getting it finished.
flygt4
