Any radiators with the in/out pipes on the left hand side?
Postby RomanV » Thu Mar 29, 2007 8:54 pm
As above...
I'm looking for a radator for my Carina, and it would be much neater/more convenient, to have the radiator pipes on the left hand side, instead of the right.
Are there any factory toyota radiators (which have fairly good cooling capacity) with the pipes on the right hand side?
Or does anyone have any good suggestions on what sort of radiator I should use?
Postby Dell'Orto » Thu Mar 29, 2007 8:56 pm
Carry on with the theme and use an Altezza one? :lol:
Postby l1ttle_d3vil » Thu Mar 29, 2007 9:23 pm
if your current one is up to the task, just get them moved over. its a real straight forward process, especially if you have access to someone who can weld. only a 30min job to swap both in/outlet over probably...
and it already bolts straight in!
Postby Dell'Orto » Thu Mar 29, 2007 9:36 pm
You might even be able to get your current one recored/another core added to make it do the job.
Postby RomanV » Thu Mar 29, 2007 9:49 pm
l1ttle_d3vil wrote:if your current one is up to the task, just get them moved over. its a real straight forward process, especially if you have access to someone who can weld. only a 30min job to swap both in/outlet over probably...
Getting any sort of fabrication work done would be against the spirit of this project. :lol:
Mmm, Boost wrote:Carry on with the theme and use an Altezza one? :lol:
Not a bad idea!
Although if this carries on much more, I might have to rebadge it as a carezza or altina or something. :P
Mmm, Boost wrote:You might even be able to get your current one recored/another core added to make it do the job.
The original radiator is well and truly $&#$%! The hose pipe end is partially broken at the top, and most of the fins have discintegrated.
Put it this way, the car used to overheat when I was giving the 3AU a bit of stick. :lol:
There's no point in recoring the radiator I've got, but perhaps getting another carina/corona/etc radiator in better condition, and recoring that could be a good idea.
Postby Bling » Thu Mar 29, 2007 10:09 pm
some K series radiators are setup how you want 8) :wink: :lol:
Postby big_boy » Thu Mar 29, 2007 10:41 pm
MA61 5M are but there big
for sale EE90
big_boy
Postby RomanV » Fri Mar 30, 2007 12:02 am
Found a picture of an altezza radiator, looks like it'll be perfect!
Pipes where I want them to be, and obviously it will be good enough for the engine. :)
Trademe, here I come. :P
Postby Dell'Orto » Fri Mar 30, 2007 12:06 am
Hahaha, I was about to post the link to that as well :lol:
Users browsing this forum: Google [Bot] and 2 guests
