sergei wrote:What stupid regulations! Can't you get exception of being factory items produced from 93?
big_boy wrote:also are you resturcted to a slider because i know of 2 good posablitys if you can use 2 pot solids
fivebob wrote:A slider should give you more pad area, but probably less piston area.
Biggest piston 2 pot sliders that I know of would be '92+ SW20, or ST215. Earlier model SW20, and probably ST185's have slightly smaller pistons.
sergei wrote:fivebob wrote:A slider should give you more pad area, but probably less piston area.
What about Altezza's (RS200) they use twin pot sliders and look pretty big to me.
groupagt4 wrote:st185 spec A has twin pots ans bigger discs i thnk
Users browsing this forum: Google [Bot] and 1 guest
