silvertop smokeing bad..
Postby ZE WAGON » Mon Apr 02, 2007 8:16 am
hi i have a standard ae101 levin with a silvertop and it seems to be using quite a bito oil and smokeing aswell, i was wondering what would be the main cause and what the easiest solution would be?..full head replacement or piston rings perhaps..
cheers for ya help.
home is where you make it!
ZE WAGON
Postby CAMB01 » Mon Apr 02, 2007 8:29 am
piston rings are worn out
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby sergei » Mon Apr 02, 2007 3:19 pm
what colour is the smoke?
if it has lots of black smoke under load and is a prefacelift silvertop then the cause might be in the injectors. If it is the case then idle will be rough as well with random stalls under hot conditions.
Postby deaf_rattle » Mon Apr 02, 2007 5:26 pm
sergei wrote:what colour is the smoke?
tell me more! do i need to put facelift injectors in?
Postby sergei » Mon Apr 02, 2007 5:57 pm
Been down that road with a few prefacelifts. Yeah facelift injectors seem to fix that problem. If you pull out facelift and prefacelift and compare you will see the difference in hole size and distance of the business part. Cleaning them does not work. It just bad design. I had 4 set of prefacelift injectors in my possesion and all of them were bad - caused to smoke and idle funny.
You could check them by unplugging each injector (one at a time) and see how much difference it makes.
Postby vvega » Mon Apr 02, 2007 6:14 pm
haha i probably have about 100 facelift injectors laying in boxes
....maybe ther is a market for them :d
v
vvega
blue smoke
Postby ZE WAGON » Mon Apr 02, 2007 6:55 pm
the smoke is a bluey grey colour and comes in large puffs when i accelerate hard or if you go to slow in a gear..mine is a 1992 is that prefacelift is it?..
ZE WAGON
Postby AceSniper » Mon Apr 02, 2007 7:41 pm
haha I prolly have afew sets to...
take it facelift ones are the same as blacktop ones
AceSniper
Postby groupagt4 » Mon Apr 02, 2007 8:12 pm
thatl be rings if it grey/blue ish
groupagt4
smoke
Postby ZE WAGON » Mon Apr 02, 2007 9:55 pm
so id be best to get a leakdown/compresion test done? cheers.
ZE WAGON
Postby matt dunn » Mon Apr 02, 2007 11:53 pm
I have a set of brand new silvertop 20V rings for sale if you need some.
re..rings
Postby ZE WAGON » Tue Apr 03, 2007 8:11 am
ok cheers matt, ill get b ack to ya when im a bitt more positive about it alll...
ZE WAGON
Postby B1NZ » Tue Apr 03, 2007 6:18 pm
just to give you an idea of what could be wrong, my 20v was using oil like a bitch, did a compression test and it was perfect.
The compression rings were fine, just the oil control rings were stuffed and I was getting blow-by, replaced rings and it hasn't used any oil since :idea:
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
replacn rings
Postby ZE WAGON » Tue Apr 03, 2007 7:31 pm
soo to replace the rings id have to pull the crank out an pistons out aswell?...is it a very difficult job?..im keen to give it a crack. what did it cost you to replace your rings?..
ZE WAGON
Postby AE82 FXGT » Tue Apr 03, 2007 7:40 pm
I don't thing you will have to take the crank out.
Just undo the bigends and rotate the crank out of the way to get the pistons out.
AE82 FXGT
Postby matt dunn » Wed Apr 04, 2007 12:22 am
AE82 FXGT wrote:I don't thing you will have to take the crank out.
have you ever done that with any sucess??
You will need to pull the head and poke them out from underneath.
Block and Crank can stay in the car.
Postby vvega » Wed Apr 04, 2007 7:40 am
B1NZ wrote:just to give you an idea of what could be wrong, my 20v was using oil like a bitch, did a compression test and it was perfect.
just for fureture referance....
oil control rings scrape teh bore to stop the oil getting to teh compressiomn rings
compression rings stop blowbye and give compression...they work both ways(up and down) but if the oil control rings let any oil past it will make them "float" on the bores and in turn the oil that makes them float on the downstroke then gets burnt in the combustion process making blue smoke
white or grey smoke is normally a indicator of bad valve stem seals
blue smoke = been though a hot combustion process
white smoke = added after the compression/combustin cycle
white mist comming from the rocker cover is also a indicator of stuffed riings
this is from the "flame"bypasssing the rings and buring the oil on the cylander walls...its actaully smoke generated from the singed oil
v
v
vvega
stupid laggy forum
vvega
Re: replacn rings
Postby B1NZ » Wed Apr 04, 2007 6:29 pm
ZE WAGON wrote:soo to replace the rings id have to pull the crank out an pistons out aswell?...is it a very difficult job?..im keen to give it a crack. what did it cost you to replace your rings?..
Not sure, I got a professional to do it, I also replaced bearings, gaskets etc, so about $1000 + parts
Subaru GF8 Wagon
B1NZ
ok
Postby ZE WAGON » Wed Apr 04, 2007 9:06 pm
ok, so i could probly buy a better whole motor for that price instead, thanks allot for ya info its all been realy helpful, cheers guys.
ZE WAGON
Users browsing this forum: Bing [Bot], Google [Bot] and 14 guests
