sergei wrote:what colour is the smoke?
if it has lots of black smoke under load and is a prefacelift silvertop then the cause might be in the injectors. If it is the case then idle will be rough as well with random stalls under hot conditions.
AE82 FXGT wrote:I don't thing you will have to take the crank out.
Just undo the bigends and rotate the crank out of the way to get the pistons out.
just for fureture referance....B1NZ wrote:just to give you an idea of what could be wrong, my 20v was using oil like a bitch, did a compression test and it was perfect.
The compression rings were fine, just the oil control rings were stuffed and I was getting blow-by, replaced rings and it hasn't used any oil since
ZE WAGON wrote:soo to replace the rings id have to pull the crank out an pistons out aswell?...is it a very difficult job?..im keen to give it a crack. what did it cost you to replace your rings?..
Users browsing this forum: Bing [Bot] and 4 guests
