if it is for RWD fitment, then 2nded.BZG|Bling wrote:
just ditch the power steering
just ditch the power steering Wink
Is there no way of moving the actual power steer pump in and out from the block to tension the belt?
if you modify the bottom of the bracket so that and alternater-type adjuster can be fitted, surely you will get enough travel to take up slack??rwd_mayhem wrote:Is there no way of moving the actual power steer pump in and out from the block to tension the belt?
it can move inwards a bit but can only be left in one position so i would have to get the perfect length belt.
Users browsing this forum: Bing [Bot], Google [Bot] and 16 guests
