power steering belt tension.
Postby rwd_mayhem » Mon Apr 02, 2007 9:37 pm
on my 4age i have a powersteering pump but no air-con, so how does the tensioner work? its in the wrong place - too low, it cant tension up the belt. can i safely just put a belt around just the crank pulley and p/s pulley? ive seen other pumps with a tensioner with them that would work very well but i cant find anyone with one.
current: 1975 Valiant Regel
rwd_mayhem
Postby bluemaumau » Mon Apr 02, 2007 9:38 pm
so when the tensioners fully tight it doesnt even tension it???
Postby rwd_mayhem » Mon Apr 02, 2007 9:59 pm
its hard to explain i need a photo. but with the tensioner up as high as it can go it wouldnt touch the belt if the belt went straight from p/s pulley to crank pulley. the tensioner pulley isnt ribbed so it cant go on the inside of the belt, if i do put it on the inside, the belt just ends up slipping then get chewed up.[/img]
rwd_mayhem
Postby rwd_mayhem » Mon Apr 02, 2007 10:03 pm
thats IH8TECs motor, how is the p/s belt setup on that, theres no tensioner at all.
rwd_mayhem
Postby Bling » Mon Apr 02, 2007 10:15 pm
not sure if this is any help at all, but............
http://www.trademe.co.nz/Trade-Me-Motor ... 551679.htm
saw this thread, then 5 minutes later saw this, so thought it may be a solution for ya. Even tho you did mention it above, maybe although its not ribbed, maybe it would still work.
third pic. you could always ask what the pic is for
Postby rwd_mayhem » Mon Apr 02, 2007 10:22 pm
lol thats my listing, got nowhere else to host pics.
can i have the belt like the blue one? when its at the green one it gets chewed up.
rwd_mayhem
Postby Bling » Mon Apr 02, 2007 10:38 pm
haha yeah just spotted that, but wasn't quick enough on the delete button :lol:
just ditch the power steering :wink:
http://www.imageshack.us/ for free hosting
Postby fangsport » Mon Apr 02, 2007 11:09 pm
if it is for RWD fitment, then 2nded.
if it's FWD, find a way of tensioning it . have a look at setting the p/s pump up on an adjuster and then getting a belt to suit ?
fangsport
Postby matt dunn » Mon Apr 02, 2007 11:36 pm
Is there no way of moving the actual power steer pump in and out from the block to tension the belt?
Postby bluemaumau » Mon Apr 02, 2007 11:50 pm
as matt says thats how you tension a 4agze p/s unit
Postby Zak » Mon Apr 02, 2007 11:50 pm
When I took the power steering off mine I'm pretty sure I used a pully off a 4AFE engine, as it was ribbed so the belt didn't slip off.
Zak
Postby rwd_mayhem » Tue Apr 03, 2007 9:32 am
just ditch the power steering Wink
really cant be bothered changing the crossmember, having no tools or a place to do it doesnt help either.
it can move inwards a bit but can only be left in one position so i would have to get the perfect length belt.
rwd_mayhem
Postby fangsport » Tue Apr 03, 2007 9:40 am
if you modify the bottom of the bracket so that and alternater-type adjuster can be fitted, surely you will get enough travel to take up slack??
fangsport
Postby big_boy » Tue Apr 03, 2007 9:44 am
what about getting the other 1/2 of the water pump pully & then going round that the P/S pump & the tensionor in you paint pic
if you havent seen the other 1/2 of the water pump pully it goes infront of what you have now to make a 1 rib belt fit
for sale EE90
big_boy
Postby rwd_mayhem » Tue Apr 03, 2007 9:51 am
im not too sure what the other half of the water pump pulley is but the problem of the tensioner not being ribbed will still chew the belt up.
rwd_mayhem
