Heapho wrote:O ok thanks can any one with a GT-T tell me what they did with putting on a BOV and POD ? cheers any help will be much appreciated
Heapho wrote:I want to know to you need to bung off where the factory BOV bolts onto the air box ? And does it matter If you take the two hose's off the vacuum line and just use one to use the BOV ?
Also what do you do If you put a POD filter on a GT-T, what do you do with the air flow sensor thats plugged into the top of the air box ?
Heapho wrote:Ive got a GFB MACH 1 Bov is a fairly decent one its not a cheap trademe copy
