2JZ-GTE Question
2JZ-GTE Question
Postby toy_s14 » Mon Apr 09, 2007 4:56 pm
The water light comes on when I'm driving up hill. The radiator is full and the overflow bottle is almost full. Any suggestions as to this problem? Car is an Aristo '92
Eddy
Current: 93 DC2 H22A
94 CD5A GSR 4G93
97 SF5 Forester S/Tb EJ20
94 S14 Silvia SR20DET Blacktop
91 RPS13 180SX SR20DET Redtop
AE85 Trueno Notchback 3AU - Parts
AE85 Levin Notchback 4AGE
toy_s14
Postby slighty_sykotic » Mon Apr 09, 2007 5:51 pm
Not window washer?
slighty_sykotic
Postby matt dunn » Mon Apr 09, 2007 10:03 pm
slighty_sykotic wrote:Not window washer?
That would be my bet.
Squirt the window washers for a minute and see if it stay on all the time,
or just fill it up.
Postby toy_s14 » Tue Apr 10, 2007 11:28 am
or just fill it up.
Yeah nah that's not the problem.
94 CD5A GSR 4G93
toy_s14
Postby Jdawg » Tue Apr 10, 2007 12:03 pm
dodgey wiring maybe. Years ago I worked on an old celica that had an intermittant misfire, mostly when going up hills. turns out the HT lead to the coil had been replaced and was a little bit short, when the engine torqued over when given a bootful it used to pull the lead out, engine would miss and settle back down, lead used to slot back in.
Jdawg
Postby toy_s14 » Wed Apr 11, 2007 11:37 am
Well when I first got the car, the light didn't come on. I've filled up the window washer bottle and the light didn't come on until this morning.....
94 CD5A GSR 4G93
toy_s14
Postby toy_s14 » Tue Apr 17, 2007 1:06 pm
Anyone?
94 CD5A GSR 4G93
toy_s14
Postby GTCRSHR » Tue Apr 17, 2007 2:49 pm
take it to toyota and get them to check for fault codes
Nothing to see here ...
GTCRSHR
Postby Jason T » Tue Apr 17, 2007 6:28 pm
The radiator over flow bottle has a low water sensor in it
Remove the bottle from car clean out the crud top up with nice clean H20 plug sensor back in no more problem
Fixing Toyota's since '87
Jason T
Postby toy_s14 » Wed Apr 18, 2007 12:06 pm
Jason T wrote:The radiator over flow bottle has a low water sensor in it
Awesome. Will try this!
94 CD5A GSR 4G93
toy_s14
Users browsing this forum: Google [Bot] and 32 guests
