hybrid ct26 or ct20b?
ct26 or ct20b
ct26 hybrid
4
27%
ct20b
11
73%
Total votes : 15
Postby touge rolla » Wed Apr 11, 2007 1:43 am
lost to a ford focus last night :(
wasn't quite so sad when i find out it was a 2.5l turbo and only one in the country, but still clearly i need more power. Should i take my ct26 and get a t4 compressor wheel and steel shaft added to it or just grab a stock ct20b and bolt that on??
touge rolla
Postby Boosted_162 » Wed Apr 11, 2007 3:40 am
CT20B and aussie downpipe.
Proven 12 second combination.
Postby sergei » Wed Apr 11, 2007 12:04 pm
Stock CT20b is good turbo but it lacks in the wastegate design. It does not work very well on no-muffler 3" system ;).
Postby flygt4 » Wed Apr 11, 2007 12:18 pm
ct20b > highflowed ct26
flygt4
Postby Bling » Wed Apr 11, 2007 1:12 pm
is this supposed to be a poll or a tech question?
I see no poll..... :wink:
Postby Al » Fri Apr 13, 2007 2:24 pm
You can cut mid-low 13s @ 105mph on a stock ct26 with around 15psi and a downpipe. I wouldn't wanna push it anymore though :lol:
With the ct20b you don't have to rape the car so much to get the same times :lol: but if you do and run 18psi or so you will run 12s with 110mph traps.
Oh yeah use 100 octane gas too :P
Al
Postby Adamal » Fri Apr 13, 2007 4:47 pm
CT20b unless you've got one of those awesome 450+hp CT26's that really honestly do exist, even though theres no dyno graphs to back that up.
Postby touge rolla » Fri Apr 13, 2007 5:52 pm
i'm sure i put poll on in first post but never mind it's there now, ct20b with external wastegate headers and down pipeit is then!
touge rolla
Postby Al » Fri Apr 13, 2007 9:18 pm
You don't need the external, unless you like the noise.
Al
Postby touge rolla » Sun Apr 15, 2007 8:54 pm
well it is a nice noise. and doing it now saves doing it later. but will see what budget allows
touge rolla
Postby Dell'Orto » Sun Apr 15, 2007 10:01 pm
touge rolla wrote:well it is a nice noise. and doing it now saves doing it later. but will see what budget allows
It does get old pretty quick though. Doing it now wont really save much later on, as if you plan on going bigger turbo you'll more than likely need to use a different manifold, or at least an adaptor which will require a different placement.
Return to Polls
