I have an HKS cannon, is quiet and sounds awesome. Bolt on 3".
About the size, afaik Sergei's experience was loss of power on his ST165 with CT20B and 2.5". Ill let him explain/correct me.
AJz wrote:gleem wrote:blunt question here exhaust off the turbo 3" or 2.5"?
if you mean which is goin to be better in this situation id say you dont need more than a 2.5, some people will disagree with that though.
As for santa, ive got a sports muffler on the end and it sounds nice, just a low rumble but not annoying. Not sure of the brand, was from Magoo Mufflers.
sergei wrote:What it does is it bleeds boost from actuator line (similar to boost tap) when the car is over certain temperature. if you have EBC or other boost control device, TVSV is not needed.
AJz wrote:you cant see the vsv from the front, from memory the solonoid is round under the intake manifold, fivebob will be able to confirm,
