Walla, $300 coilovers that perform as good as any aftermarket ones.
Mr Revhead wrote:Walla, $300 coilovers that perform as good as any aftermarket ones.
yeah right....
but will work, and for a road car will be fine
cutting and compressing = dodgy if going to far
you may also find you need RCAs to eliminate bumpsteer.
ae92 shocks are a good source for shorter shocks. cut housings to suit as mentioned above and get some springs that fit properly
Get AE92 inserts, like $100 depending on who you know. Work out how much shorter they are than stock, im thinking 60mm??? Not 100% sure about DX, then instead of making a spacer cut the strut down as far as you wanna go lower say 40mm, then just use a 20mm spacer. Shock/handling upgrade, 40mm Drop and No loss in captivity
Users browsing this forum: Bing [Bot], Google [Bot] and 3 guests
